Hi
I am using the MATLAB interface to design a MPC for a trajectory tracking problem. The cost function I am using is least square type. I tried to set different value for the weight matrix at each stage in a horizon and already made it in MATLAB script by using the method ocp.set(). Now I generated the code from MATLAB script and tried to do the same thing in S-function in my Simulink model. I took a look at the example “simulink_example_advanced.m” and learned how to set the cost as an input for S-function. However, the approach shown in this example sets the same weight value for all the stages in a horizon. So my question is, whether there is a way to set different value for the weight in different stage in a horizon, just like what can be achieved in MATLAB, Python or C interfaces? If possible, how can I achieve this?
Thanks in advance!
FreyJo
March 8, 2023, 7:30pm
2
this is not possible in the Simulink interface for now.
You would have to modify the interface.
Either in Simulink:
% Copyright 2019 Gianluca Frison, Dimitris Kouzoupis, Robin Verschueren,
% Andrea Zanelli, Niels van Duijkeren, Jonathan Frey, Tommaso Sartor,
% Branimir Novoselnik, Rien Quirynen, Rezart Qelibari, Dang Doan,
% Jonas Koenemann, Yutao Chen, Tobias Schöls, Jonas Schlagenhauf, Moritz Diehl
% This file is part of acados.
% The 2-Clause BSD License
% Redistribution and use in source and binary forms, with or without
% modification, are permitted provided that the following conditions are met:
% 1. Redistributions of source code must retain the above copyright notice,
% this list of conditions and the following disclaimer.
% 2. Redistributions in binary form must reproduce the above copyright notice,
% this list of conditions and the following disclaimer in the documentation
% and/or other materials provided with the distribution.
This file has been truncated. show original
* Copyright 2019 Gianluca Frison, Dimitris Kouzoupis, Robin Verschueren,
* Andrea Zanelli, Niels van Duijkeren, Jonathan Frey, Tommaso Sartor,
* Branimir Novoselnik, Rien Quirynen, Rezart Qelibari, Dang Doan,
* Jonas Koenemann, Yutao Chen, Tobias Schöls, Jonas Schlagenhauf, Moritz Diehl
* This file is part of acados.
* The 2-Clause BSD License
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
Or more general in the solver:
