I started using acados with python, and i started with minimal example closed loop.py, but i get this error , am using pycharm professional. Can someone help.
I
thanks in advance
I
thanks in advance
Please check if LD_LIBRARY_PATH is set correctly in Pycharm.
https://docs.acados.org/interfaces/index.html#installation
Something like this:
os.system(echo "LD_LIBRARY_PATH=$LD_LIBRARY_PATH")
Cheers
Right, this was an error in the race car example, was already reported.
I just merged this into master, which contains the fix.
But it works from the terminal outside pycharm
Did you try this?
Hi FreyJo
That’s what I got after running the corrected one
and this is the result from the terminal
Hi @Agent007,
this seems like another issue of the PyCharm virtual environments.
It downloads the file into the wrong folder, because the directories inside the environment are not as expected.
Please post your error messages in this form:
error
messages
such that one can refer to them.
I still think if you set up the environment as mentioned here, there should be no issue.
Hi @FreyJo now i can run the python examples but when I run the race cars example I got this error
Thanks
Great!
So this was indeed the solution for your pycharm issues?
The example was modified lately, to just print warnings when exiting with maximum iterations instead of throwing an exception.
Please check out the latest version.
Hi @FreyJo , the problem was the venv and now everything runs fine now. But till now i do not get results form car example even with the latest version !!
Hi @FreyJo Is there any documentation explaining the (for example) car race python example.
Best
