Parameteric OCP with path constraint and LS cost
@FreyJo @jay101
I also got the same error in matlab interface ,when parameter p needs an update at each stage.
.../casadi/core/sx_function.cpp:147: Code generation is not possible since variables [P_0, P_1] are free.
1.this is an example with nonempty parameter vector:
2.Here the parameter values are set/updated stagewise:
I tried the solution you mentioned above . But its not work.
Maybe, its different between Python and Matlab.
So, Are there any examples of MATLAB?
Thank you in advance.
Gaofei
