How to set up properly onlineData in Acado
I am developing an MPC controller for vehicle trajectory tracking. To achieve this, I use the bicycle model of the vehicle. When I include the longitudinal velocity Vx as a state variable (along with its time derivative), the optimization does not proceed, even if it is constant and properly initialized. On the other hand, if I remove Vx from the state vector and declare it separately as a variable, the optimization runs successfully. Additionally, I define the buses in Simulink and assign an initial value to enable the simulation. I am attaching the implementation code.
clc;
clear all;
close all;
clear mex;
% Controller settings
Ts = 0.01; % Sampling time
% Vehicle parameters of bicycle model (dynamic)
Vehicle_parameter;
%% ACADO set up
% Controller states
DifferentialState Vx doty dotpsi x y psi;
Control delta; % Definition of control variable
%OnlineData Vx;  % Vx is now a parameter instead of a constant
%% Calculation of forces from the nonlinear tire model
s_f = 0.1;
s_r = 0.1;
Cf_non = par.Ccf;
Cr_non = par.Ccr;
Fxf = s_f * par.Csf;
Fxr = s_r * par.Csr;
% Now Vx will be passed from Simulink, we no longer define it here
%Vx = 10; % Constant velocity
f_ctrl = [
    dot(Vx) == doty*dotpsi;
    dot(doty) == (Fxf*sin(delta) + Cf_non*(delta-(doty + par.lf*dotpsi)/(Vx))*cos(delta))/par.m - (Cr_non*(doty - par.lf*dotpsi)/(Vx))/par.m - Vx*dotpsi;...
    dot(dotpsi) == (Fxf*sin(delta) + Cf_non*(delta-(doty + par.lf*dotpsi)/(Vx))*cos(delta))*par.lf/par.Iz + (Cr_non*(doty - par.lf*dotpsi)/(Vx))*par.lr/par.Iz;...
    dot(x) == Vx*cos(psi) - doty*sin(psi);...
    dot(y) == Vx*sin(psi) + doty*cos(psi);...
    dot(psi) == dotpsi];
%% ACADO: Controller formulation
acadoSet('problemname', 'PF_problem');
Np = 20;
ocp = acado.OCP(0.0, Np*Ts, Np);
% Residual function definition based on ACADO
h = [diffStates ; controls];
hN = [diffStates];  % terminal
% Initialization weights
W = acado.BMatrix(eye(length(h)));
WN = acado.BMatrix(eye(length(hN)));
% Cost definition
ocp.minimizeLSQ(W, h);
ocp.minimizeLSQEndTerm(WN, hN);  % terminal
% Constraints definition
beta_thd  = 100 / 180 * pi;  % absolute sideslip
delta_thd = 360 / 180 * pi / par.i_steer;
y_thd = 100;
psi_thd = 2*pi;
% Constraints in ACADO
ocp.subjectTo(-y_thd  <= y <= y_thd);
ocp.subjectTo(-psi_thd <= psi <= psi_thd);
%ocp.subjectTo(-delta_thd <= delta <= delta_thd);
% Definition of ACADO prediction model
ocp.setModel(f_ctrl);  % Set the model dynamics
% ACADO settings
mpc = acado.OCPexport(ocp);
mpc.set('HESSIAN_APPROXIMATION', 'GAUSS_NEWTON');
mpc.set('DISCRETIZATION_TYPE', 'MULTIPLE_SHOOTING');
mpc.set('INTEGRATOR_TYPE', 'INT_IRK_GL2');
mpc.set('NUM_INTEGRATOR_STEPS', 3 * Np);
mpc.set('LEVENBERG_MARQUARDT', 1e-4);
mpc.set('SPARSE_QP_SOLUTION', 'FULL_CONDENSING_N2');
mpc.set('QP_SOLVER', 'QP_QPOASES3');
mpc.set('MAX_NUM_QP_ITERATIONS', 200);
mpc.set('HOTSTART_QP', 'YES');
mpc.set('GENERATE_SIMULINK_INTERFACE', 'YES');  % Interface with Simulink
%% Export and Compile flags
EXPORT = 1;
COMPILE = 1;
% Export code to the defined folder
if EXPORT
    mpc.exportCode('export_MPC');
% Compilation of the S-function using autogenerated make script
if COMPILE
    global ACADO_;
    copyfile([ACADO_.pwd '/../../external_packages/qpoases3'], 'export_MPC/qpoases3')
    cd export_MPC
    make_acado_solver_sfunction
    copyfile('acado_solver_sfun.mex*', '../')
    cd ..
%% Initial MPC settings
disp('Initialization')
Vini = 10;
X0 = [Vini 0 0 0 0 0];  % Initial states conditions
% Initialize controller bus
input.x  = repmat(X0, Np + 1, 1).';      % Size Np + 1
%input.od = zeros(Np+1,1);            % Size Np + 1
input.od = repmat(Vini, Np + 1, 1)';
Uref     = zeros(Np, 1);
input.u  = Uref.';                        % Control inputs
input.y  = [repmat(X0, Np, 1) Uref].';    % Reference trajectory
input.yN = X0.';                         % Terminal reference
input.W  = diag([0 0 0 0 0 5 1]);          % Weight tuning
input.WN = diag([0 0 0 0 5 1]);            % Terminal weight tuning
input.x0 = X0.';                         % Initial state
%input.od = ones(1,Np + 1) * Vx_ini;     % Online data (Vx as an external parameter)
% Inicializar la estructura 'init' que pasará datos al bloque de Simulink
init.x   = input.x(:).';
init.u   = input.u(:).';
init.y   = input.y(:).';
init.yN  = input.yN(:).';
init.W   = input.W(:).';
init.WN  = input.WN(:).';
init.x0  = input.x0(:).';
%init.od  = input.od(:).';  % Asegurar que se inicializa la entrada od (Vx)
is there a particular reason to use ACADO instead of acados?
Note that ACADO is not maintained anymore and this forum is meant for acados users.
Because i did not know about the existance of acados. And i am making the implementation by using ACADO. Could you please help me? Or should I ask in other forum specialised in ACADO. In that case, could you provide the name of the forum?
Regards, Marc.
There is no ACADO forum.
The software is not maintained anymore, see update README with note on current development and acados reference by FreyJo · Pull Request #304 · acado/acado · GitHub
I strongly suggest using acados instead, especially when starting with a new MPC implementation.
