Hello all,
My initial goal is to build up the incremental MPC problem, using the change of control input to replace the absolute control input. What’s more, I want to define the cost function like
and replace the x with the \Delta u, which turns out:
The way I do is to pre-define all matrices which are necessary of setting up such cost function as QP.
I set the cost function type as ‘EXTERNAL’, and define every matrix which combines together as the Hessian matrix \bar H.
But it turns out the error is about:
RuntimeError: Error in Function::Function for 'LMPC_cost_ext_cost_e_fun' [MXFunction] at .../casadi/core/function.cpp:280:
.../casadi/core/function_internal.cpp:146: Error calling MXFunction::init for 'LMPC_cost_ext_cost_e_fun':
.../casadi/core/mx_function.cpp:406: LMPC_cost_ext_cost_e_fun::init: Initialization failed since variables [delta_kappa] are free. These symbols occur in the output expressions but you forgot to declare these as inputs. Set option 'allow_free' to allow free variables.
Which means I lost the \Delta u as the control variable.
Just wanted to know if anyone has experience setting such external cost function and solve it.
Below I provided the snippet code of settings of model and the external cost function expression:
## CasADi model
# State variables
posy = MX.sym('posy')
yaw = MX.sym('yaw')
kappa = MX.sym('kappa')
# Parameters
v = vehicle_params['velocity']
# Control inputs
delta_kappa = MX.sym('delta_kappa')
# Build the state vector by vertically concatenating the state variables
# State vector
x = vertcat(posy, yaw, kappa)
# Build the control vector by vertically concatenating the control inputs
# Control vector
u = vertcat(delta_kappa)
# Define cost function
ocp.cost.cost_type = 'EXTERNAL' # Cost type at intermiate shooting nodes (1 to N-1)
ocp.cost.cost_type_e = 'EXTERNAL' # Cost type at terminal shooting node (N)
C_bar = np.zeros((nx*N, nu*N))
# gather all needed matrices
A_aug = pred_mb_model.A_d_prime
B_aug = pred_mb_model.B_d_prime[:, 0]
C_prime = np.array([[1, 0, 0],
[0, 1, 0],
[0, 0, 1]])
A_hat = np.vstack([np.linalg.matrix_power(A_aug, i) for i in range(1, N+1)])
Q_bar = np.kron(np.eye(N), C_prime.T @ Q @ C_prime)
R_bar = np.kron(np.eye(N), R)
T_bar = np.kron(np.eye(N), Qe @ C_prime)
for i in range(N):
for j in range(i+1):
c_block = np.linalg.matrix_power(A_aug, i-j) @ B_aug # represent the influence of state at i time step when control input employed at j time step
C_bar[i * nx:(i+1) * nx, j * nu:(j+1) * nu] = c_block # thw power of the A_aug matrix
H_bar = C_bar.T @ Q_bar @ C_bar + R_bar # H matrix
# Cost function weights
ocp.cost.W = H_bar
ocp.cost.W_e = H_bar
# S = np.tril(np.ones((N * nu, N * nu)))S
S = MX.ones(N * nu, 1)
# Extract the state and control input variables from p
x_t = ocp.model.p[:nx] # current state (nx, 1)
r = ocp.model.p[nx:] # reference states (nx*N, 1)
f = (x_t.T @ A_hat.T @ Q_bar @ C_bar - r.T @ T_bar @ C_bar).T
# Initial references
ocp.model.cost_expr_ext_cost = 0.5 * ((S @ pred_mb_model.u).T @ H_bar @ (S @ pred_mb_model.u)) + f.T @ (S @ pred_mb_model.u)
ocp.model.cost_expr_ext_cost_e = 0.5 * ((S @ pred_mb_model.u).T @ H_bar @ (S @ pred_mb_model.u))
Best regards,
Brian
