I would like to formulate a path following constraint like the following:
-s_l < q - y(z) < + s_u
where q is the generalized position vector (subset of sym.x), z is an algebraic variable which is not part of the dynamics, sl,su are slack variables and y = q_2z + q_1(1-z).
What i am trying to achieve with this is to have the state close to a line path from q1 to q2. But i do not want to pre-specify the timing.
Question: So my general question is, how can i achieve the above? I will describe my current approach, with some additional questions along the way.
Approach 1:
% variables:
s = SX.sym('s' ,1) ;
x1 = SX.sym('x1' ,3) ;
x2 = SX.sym('x2' ,3) ;
ocp_model.set('sym_p', [x1;x2]);
ocp_model.set('sym_z', s);
% Dynamics:
expr_f_impl = sym_xdot - expr_f_expl;
ocp_model.set('dyn_type', 'implicit');
ocp_model.set('dyn_expr_f', [model.expr_f_impl;0]);
%constraints: -> they are slacked
path_constr = x2*s +x1*(1-s);
state = model.sym_x([1,2,4]);
path_error = state - path_constr;
But when i try to solve it, i get:
iter res_stat res_eq res_ineq res_comp qp_stat qp_iter alpha
0 NaN NaN NaN 0.000000e+00 0 0 0.000000e+00
Question1: I do not add the constraint on terminal state, as it seems terminal constraints on algebraic variables are not supported (got some error messages for constr_h_expr_e when i deleted the corresponding terminal constraints). Am i right about this?
Approach 2:
If the dynamics are not appended by a zero:
ocp_model.set('dyn_expr_f', [model.expr_f_impl]);
then i get this error:
Error using casadi.GenericMatrixCommon/jtimes
Error in SX::jtimes at .../casadi/core/generic_matrix.hpp:1191:
.../casadi/core/generic_matrix.hpp:1164: Assertion "v.size1() == ex.size1() && v.size2()
0.000000e+00x.size2() == 0" failed:
'v' has inconsistent dimensions
Error in generate_c_code_implicit_ode (line 189)
ADJ = jtimes(f_impl, x_xdot_z_u, multiplier, true);
Question2: I initially appended the dynamics with a zero to get arround this error, but i guess i created a singular jacobian which is why the first approach returns NaN. Am i right about this ?
- According to this, i can add constraints on algebraic variables, to ensure z is in [0,1].
