Hi there,
I am trying to implement an ocp to control the CSTR system. I would like to use discrete dynamics, but the generated C code does not compile and returns the following error:
acados_sim_solver_cstr.c:86:23: error: use of undeclared identifier 'DISCRETE'
plan.sim_solver = DISCRETE;
1 error generated.
make: *** [acados_sim_solver_cstr.o] Error 1
You can find below my whole implementation. I thought that specifying disc_dyn_expr in the model and integrator_type = “DISCRETE” in the ocp instance would suffice, especially since all the example files (including getting_started/example_ocp_dynamics_formulations.py) run normally.
Thank you a lot for your input!
Tudor
from acados_template import *
from casadi import *
from scipy.linalg import solve_discrete_are
xr1 = np.array(
2.1402105301746182e00,
1.0903043613077321e00,
1.1419108442079495e02,
1.1290659291045561e02,
ur1 = np.array([14.19, -1113.50])
xr2 = np.array([2.7151681, 1.02349152, 105.50585058, 100.8920758])
ur2 = np.array([13.66640639, -3999.58908628])
xr3 = np.array([2.97496989, 0.95384459, 101.14965441, 95.19386292])
ur3 = np.array([12.980148, -5162.95653026])
def export_cstr_model(dt: float, rk4_nodes: int = 6):
c_A = SX.sym("c_A")
c_B = SX.sym("c_B")
theta = SX.sym("theta")
theta_K = SX.sym("theta_K")
u_1 = SX.sym("u_1")
u_2 = SX.sym("u_2")
x = vertcat(c_A, c_B, theta, theta_K)
u = vertcat(u_1, u_2)
c_A_dot = SX.sym("c_A_dot")
c_B_dot = SX.sym("c_B_dot")
theta_dot = SX.sym("theta_dot")
theta_K_dot = SX.sym("theta_K_dot")
xdot = vertcat(c_A_dot, c_B_dot, theta_dot, theta_K_dot)
k_10 = 1.287e12 # [h^-1]
k_20 = 1.287e12 # [h^-1]
k_30 = 9.043e9 # [h^-1]
E_1 = -9758.3 # [1]
E_2 = -9758.3 # [1]
E_3 = -8560.0 # [1]
H_1 = 4.2 # [kJ.mol^-1]
H_2 = -11.0 # [kJ.mol^-1]
H_3 = -41.85 # [kJ.mol^-1]
rho = 0.9342 # [kg.L^-1]
C_p = 3.01 # [kJ/(kg.K)]
k_w = 4032.0 # [kJ/(h.m^2.K)]
A_R = 0.215 # [m^2]
V_R = 10.0 # [l]
m_K = 5.0 # [kg]
C_PK = 2.0 # [kJ/(kg.K)]
c_A0 = 5.1 # [mol/l]
theta_0 = 104.9 # [°C]
k_1 = k_10 * exp(E_1 / (x[2] + 273.15))
k_2 = k_20 * exp(E_2 / (x[2] + 273.15))
k_3 = k_30 * exp(E_3 / (x[2] + 273.15))
f_cont = Function(
"f_cont",
[x, u],
vertcat(
u[0] * (c_A0 - x[0]) - k_1 * x[0] - k_3 * x[0] * x[0],
-u[0] * x[1] + k_1 * x[0] - k_2 * x[1],
u[0] * (theta_0 - x[2])
+ (x[3] - x[2]) * k_w * A_R / (rho * C_p * V_R)
- (k_1 * x[0] * H_1 + k_2 * x[1] * H_2 + k_3 * x[0] * x[0] * H_3)
/ (rho * C_p),
(u[1] + k_w * A_R * (x[2] - x[3])) / (m_K * C_PK),
new_x = x
for j in range(rk4_nodes):
k1 = f_cont(new_x, u)
k2 = f_cont(new_x + dt / 2 * k1, u)
k3 = f_cont(new_x + dt / 2 * k2, u)
k4 = f_cont(new_x + dt * k3, u)
new_x += dt / 6 * (k1 + 2 * k2 + 2 * k3 + k4)
model.f_impl_expr = xdot - f_cont(x, u)
model.f_expl_expr = f_cont(x, u)
model.disc_dyn_expr = new_x
model.x = x
model.xdot = xdot
model.u = u
model.name = "cstr"
return model
def export_cstr_ocp(
dt: float = 20 / 3600,
N: int = 100,
x0: np.ndarray = np.array([1.0, 0.5, 100.0, 100.0]),
x_ref: np.ndarray = xr1,
u_ref: np.ndarray = ur1,
ocp.model = export_cstr_model(dt=dt)
ocp.dims.N = N
ocp.solver_options.tf = dt * N
nx = ocp.model.x.size()[0]
nu = ocp.model.u.size()[0]
x = ocp.model.x
u = ocp.model.u
Q = np.diag([0.2, 1.0, 0.5, 0.2])
R = np.diag([0.5, 5.0e-7])
C_x = np.vstack((np.eye(nx), -np.eye(nx)))
d_x = np.array([10.0, 10.0, 150.0, 150.0, 0.0, 0.0, -98.0, -92.0])
q_x = 2 * nx
C_u = np.vstack((np.eye(nu), -np.eye(nu)))
d_u = np.array([35.0, 0.0, -3.0, 9000.0])
q_u = 2 * nu
epsilon = 1.0e-3
# cost function
jac_f_x = Function("jac_f_x", [x, u], [jacobian(ocp.model.disc_dyn_expr, x)])
jac_f_u = Function("jac_f_u", [x, u], [jacobian(ocp.model.disc_dyn_expr, u)])
A = np.array(jac_f_x(x_ref, u_ref))
B = np.array(jac_f_u(x_ref, u_ref))
ocp.cost.cost_type = "LINEAR_LS"
ocp.cost.W = np.block([[Q, np.zeros((nx, nu))], [np.zeros((nu, nx)), R]])
P = np.array(solve_discrete_are(A, B, Q, R))
ocp.cost.W_e = P
ocp.cost.Vx = np.vstack((np.eye(nx), np.zeros((nu, nx))))
ocp.cost.Vx_e = np.eye(nx)
ocp.cost.Vu = np.vstack((np.zeros((nx, nu)), np.eye(nu)))
ocp.cost.yref = np.append(x_ref, u_ref)
ocp.cost.yref_e = x_ref
# constraints
ocp.constraints.x0 = x0
ocp.constraints.lbx = d_x[:nx]
ocp.constraints.ubx = d_x[nx:]
ocp.constraints.idxbx = np.arange(nx)
ocp.constraints.lbu = d_u[:nu]
ocp.constraints.ubu = d_u[nu:]
# solver options
# ocp.solver_options.qp_solver = "FULL_CONDENSING_QPOASES"
ocp.solver_options.qp_solver = "PARTIAL_CONDENSING_HPIPM"
ocp.solver_options.hessian_approx = "GAUSS_NEWTON"
# ocp.solver_options.integrator_type = "ERK"
ocp.solver_options.integrator_type = "DISCRETE"
ocp.solver_options.nlp_solver_type = "SQP_RTI"
return ocp
def run_closed_loop_simulation(
N: int = 100,
xr: np.ndarray = xr1,
ur: np.ndarray = ur1,
ocp = export_cstr_ocp(dt=dt, N=N, x0=x0, x_ref=xr, u_ref=ur)
acados_ocp_solver = AcadosOcpSolver(
ocp, json_file="acados_ocp_" + ocp.model.name + ".json"
acados_sim_solver = AcadosSimSolver(
ocp, json_file="acados_sim_" + ocp.model.name + ".json"
Nsim = 350
x_sim = np.zeros((Nsim + 1, nx))
u_sim = np.zeros((Nsim, nu))
x_sim[0, :] = x0
xcurrent = x0
n_convergence = Nsim + 1
for i in range(Nsim):
# solve ocp
acados_ocp_solver.set(0, "lbx", xcurrent)
acados_ocp_solver.set(0, "ubx", xcurrent)
status = acados_ocp_solver.solve()
acados_ocp_solver.print_statistics()
if status != 0:
raise Exception(
"acados ocp solver returned status {}. Exiting.".format(status)
u_sim[i, :] = acados_ocp_solver.get(0, "u")
# simulate system
acados_sim_solver.set("x", xcurrent)
acados_sim_solver.set("u", u_sim[i, :])
status = acados_sim_solver.solve()
if status != 0:
raise Exception(
"acados sim solver returned status {}. Exiting.".format(status)
# update state
xcurrent = acados_sim_solver.get("x")
x_sim[i + 1, :] = xcurrent
# check if there is convergence in relative norm
if np.linalg.norm(x_sim[i + 1, :] - xr) / np.linalg.norm(xr) < 1e-3:
n_convergence = i + 1
break
x_sim = x_sim[: n_convergence + 1, :]
u_sim = u_sim[:n_convergence, :]
return x_sim, u_sim, n_convergence
if __name__ == "__main__":
run_closed_loop_simulation()
