There is indeed an update:
The interfaces now allow for a more flexibel way of setting bounds on the initial state vector x0.
Instead of setting the property constr_x0, you can now set the following properties.
constr_Jbx_0, the matrix that specifies which components of x0 are bounded
constr_lbx_0, constr_ubx_0 the lower and upper bounds on x0
I did not play around with that a lot in Matlab, so please let me know if there is an issue
