Simulating an external C model
I’m using acados to solve a nonlinear MPC with the Python interface. The dynamics are given by external C functions, explicitly implementing the disc_dyn_fun and disc_dyn_fun_jac functions. I’ve already implemented the MPC solver and it works.
However, now I’d like to add a forward sweep after the SQP-RTI solution is obtained to make sure that the solution adheres the dynamics even if the SQP is not converged. For this, I’d simulate the system from the given initial state applying the optimized input sequence.
As far as I understand, I should be able to use AcadosSimSolver for this, but it doesn’t work. I tried 2 ways of implementing it:
1) Directly generating from the ocp:
Code snippet:
        ocp.model.dyn_ext_fun_type = 'generic'
        ocp.model.dyn_disc_fun = 'disc_dyn_fun'
        ocp.model.dyn_disc_fun_jac = 'disc_dyn_fun_jac'
        ocp.solver_options.integrator_type = 'DISCRETE'
        ocp_solver = AcadosOcpSolver(ocp)
        sim_solver = AcadosSimSolver(ocp)
Error:
make: *** No rule to make target 'sim_shared_lib'.  Stop.
acados was compiled without OpenMP.
  File "mpc.py", line 151, in __init__
  File "acados/interfaces/acados_template/acados_template/acados_sim_solver.py", line 285, in __init__
    self.shared_lib = get_shared_lib(self.shared_lib_name, winmode=self.winmode)
  File "acados/interfaces/acados_template/acados_template/utils.py", line 130, in get_shared_lib
    shared_lib = DllLoader(shared_lib_name)
  File "/usr/lib/python3.10/ctypes/__init__.py", line 374, in __init__
OSError: c_generated_code/libacados_sim_solver_generic_robot.so: cannot open shared object file: No such file or directory
2) Using the same model but defining a separate sim object:
Code snippet:
        sim = AcadosSim()
        sim.solver_options.T = self.dt
        sim.solver_options.integrator_type = 'DISCRETE'
        sim.model = ocp.model
Error:
Exception: Invalid integrator_type value. Possible values are:
ERK,
IRK,
GNSF.
You have: DISCRETE.
Could you help to solve this issue?
Peter
Hi Peter :waving_hand:
the sim solver does indeed not support discrete dynamics at the moment. I would recommend to directly interface your c function using ctypes:
