QP solver status 3 with qp_solver_iter_max > 5 and Nonlinear Constraints
Hi everyone,
First, thank you some much for your nice work on acados!
I am using the Python interface to design an MPC controller for a group of 3 robots (point masses with a double integrator dynamic model for now). I am trying to add nonlinear constraints for collision avoidance. I used both euclidian distance constraints and control barrier functions.
My model is discrete and I use SQP and full condensing HPIPM for the solver. I get satisfying results when I set a maximum number of iterations for the qp solver equal or lower than 5. But I always reach the maximum of sqp iterations (here I set it to 100). However, if I increase qp_solver_iter_max in order to get a better solution, I get an qp error status 3. Would you have any idea why? The problem seems to be independent from the type of constraint I use.
Here is the code (ocp solver and closed-loop simulation) :
from acados_template import *
from double_integrator_model_discrete import export_2d_model_discrete
from utils import plot_multi_robots
from scipy.linalg import block_diag
import casadi as ca
from model_integrator_discrete import simulate_discrete_model
from casadi import MX, vertcat
def main():
    print("Exporting solver ...")
    N = 20
    Tf = 1.0
    Ts = Tf/N
    r = 0.2
    gamma = 2.0 # safety coefficient for the control barrier function
    # set model
    model = export_2d_model_discrete()
    ocp.model:AcadosModel = model
    nx = model.x.size()[0]
    nu = model.u.size()[0]
    print("State size: ",nx)
    print("Input size: ",nu)
    # set dimensions
    ocp.dims.N = N
    ocp.dims.nx = nx
    ocp.dims.nu = nu
    ocp.dims.nbx = nx
    ocp.dims.nbu = nu
    # set cost with control barrier function
    Qi = np.diag([30,30,20,20])
    Qif = np.diag([100,100,10,10])
    Q = block_diag(Qi,Qi,Qi)
    Qf = block_diag(Qif,Qif,Qif)
    Ri = np.diag([0.1,0.1])
    R = block_diag(Ri,Ri,Ri)
    # set goal
    goal = np.array([2.0,4.0,0.0,0.0,6.0,2.0,0.0,0.0,6.0,6.0,0.0,0.0])
    # the 'EXTERNAL' cost type can be used to define general cost terms
    # NOTE: This leads to additional (exact) hessian contributions when using GAUSS_NEWTON hessian.
    #ocp.cost.cost_type = "EXTERNAL"
    #ocp.cost.cost_type_e = "EXTERNAL"
    ocp.cost.cost_type = "LINEAR_LS"
    # states for constraints and costs
    x = ocp.model.x
    # inputs for constraints and costs
    u = ocp.model.u
    ny = nx+nu
    ny_e = nx
    # linear cost
    ocp.cost.W_e = Q
    ocp.cost.W = block_diag(Q, R)
    ocp.cost.Vx = np.zeros((ny,nx))
    ocp.cost.Vx[:nx,:nx] = np.eye(nx)
    Vu = np.zeros((ny, nu))
    Vu[nx : nx + nu, 0:nu] = np.eye(nu)
    ocp.cost.Vu = Vu
    ocp.cost.Vx_e = np.eye(nx)
    yref = np.zeros((ny,))
    yref[:nx] = goal
    ocp.cost.yref = yref
    ocp.cost.yref_e = goal
    # set states and inputs boundaries
    Fmax = 2
    xmax = 40
    vmax = 15
    x0 = np.array([6.0,4.0,0.0,0.0,2.0,6.0,0.0,0.0,2.0,2.0, 0.0, 0.0])
    #ocp.constraints.constr_type ='BGP'
    ubu = np.array([+Fmax,+Fmax,+Fmax,+Fmax,+Fmax,+Fmax])
    ocp.constraints.lbu = -ubu
    ocp.constraints.ubu = ubu
    ubx = np.array([xmax,xmax,vmax,vmax,xmax,xmax,vmax,vmax,xmax,xmax,vmax,vmax])
    ocp.constraints.lbx = -ubx
    ocp.constraints.ubx = ubx
    ocp.constraints.ubx_0 = ubx
    ocp.constraints.lbx_0 = -ubx
    ocp.constraints.ubx_e = ubx
    ocp.constraints.lbx_e = -ubx
    ocp.constraints.idxbx = np.arange(nx)
    ocp.constraints.idxbx_e = np.arange(nx)
    # intial condition constraint
    ocp.constraints.x0 = x0
    ## Collision avoidance constraints
    # dist12 = (x[0]-x[4])**2+(x[1]-x[5])**2
    # dist13 = (x[0]-x[8])**2+(x[1]-x[9])**2
    # dist32 = (x[8]-x[4])**2+(x[9]-x[5])**2
    cbf12 = (x[0]-x[4])**2 + (x[1]-x[5])**2 - (2*r*r)
    cbf12dot = 2*(x[0]-x[4])*(x[2]-x[6]) + 2*(x[1]-x[5])*(x[3]-x[7])
    h12 = cbf12dot + gamma*cbf12
    cbf13 = (x[0]-x[8])**2 + (x[1]-x[9])**2 - (2*r*r)
    cbf13dot = 2*(x[0]-x[8])*(x[2]-x[10]) + 2*(x[1]-x[9])*(x[3]-x[11])
    h13 = cbf13dot + gamma*cbf13
    cbf32 = (x[8]-x[4])**2 + (x[9]-x[5])**2 - (2*r*r)
    cbf32dot = 2*(x[8]-x[4])*(x[10]-x[6]) + 2*(x[9]-x[5])*(x[11]-x[7])
    h32 = cbf32dot + gamma*cbf32
    # dist1obs = (x[0]-4)**2+(x[1]-4)**2
    ocp.constraints.lh = np.array([0.1,0.1,0.1])
    ocp.constraints.uh = np.array([100.0,100.0,100.0])
    ocp.model.con_h_expr = vertcat(h12,h13,h32)
    ocp.constraints.uh_e = ocp.constraints.uh
    ocp.constraints.lh_e = ocp.constraints.lh
    ocp.model.con_h_expr_e = ocp.model.con_h_expr
    # IF SOFT
    ocp.constraints.idxsh = np.array([0])
    ocp.constraints.idxsh_e = np.array([0])
    Zh = 1e6 * np.ones(1)
    zh = 1e4 * np.ones(1)
    ocp.cost.zl = zh
    ocp.cost.zu = zh
    ocp.cost.Zl = Zh
    ocp.cost.Zu = Zh
    ocp.cost.zl_e = np.concatenate((ocp.cost.zl_e, zh))
    ocp.cost.zu_e = np.concatenate((ocp.cost.zu_e, zh))
    ocp.cost.Zl_e = np.concatenate((ocp.cost.Zl_e, Zh))
    ocp.cost.Zu_e = np.concatenate((ocp.cost.Zu_e, Zh))
    # set options
    ocp.solver_options.qp_solver = 'FULL_CONDENSING_HPIPM' # FULL_CONDENSING_QPOASES
    # PARTIAL_CONDENSING_HPIPM, FULL_CONDENSING_QPOASES, FULL_CONDENSING_HPIPM,
    # PARTIAL_CONDENSING_QPDUNES, PARTIAL_CONDENSING_OSQP, FULL_CONDENSING_DAQP
    ocp.solver_options.nlp_solver_type = 'SQP' # SQP_RTI, SQP
    ocp.solver_options.hessian_approx = 'GAUSS_NEWTON' # 'GAUSS_NEWTON', 'EXACT'
    ocp.solver_options.integrator_type = 'DISCRETE'
    ocp.solver_options.regularize_method = 'CONVEXIFY'
    ocp.solver_options.nlp_solver_max_iter = 100
    ocp.solver_options.qp_solver_iter_max = 5
    ocp.solver_options.levenberg_marquardt = 10.0
    ocp.solver_options.print_level = 0
    # set prediction horizon
    ocp.solver_options.tf = Tf
    ocp_solver = AcadosOcpSolver(ocp, json_file = 'acados_ocp_discrete.json')
    print("Exported solver")
    Nsim = 300
    simX = np.ndarray((Nsim+1, nx))
    simU = np.ndarray((Nsim, nu))
    timings = np.zeros((Nsim,))
    simX[0,:] = x0
    for i in range(0,Nsim):
        # first guess for u
        # uinit = np.array([(goal[0]-simX[i, 0])/np.sqrt((goal[0]-simX[i, 0])**2+(goal[1]-simX[i, 1])**2),
        #                 (goal[1]-simX[i, 1])/np.sqrt((goal[0]-simX[i, 0])**2+(goal[1]-simX[i, 1])**2),
        #                 (goal[4]-simX[i, 4])/np.sqrt((goal[4]-simX[i, 4])**2+(goal[5]-simX[i, 5])**2),
        #                 (goal[5]-simX[i, 5])/np.sqrt((goal[4]-simX[i, 4])**2+(goal[5]-simX[i, 5])**2),
        #                 (goal[8]-simX[i, 8])/np.sqrt((goal[8]-simX[i, 8])**2+(goal[9]-simX[i, 9])**2),
        #                 (goal[9]-simX[i, 9])/np.sqrt((goal[8]-simX[i, 8])**2+(goal[9]-simX[i, 9])**2) ])
        uinit = np.zeros((6,))
        for k in range(N):
            ocp_solver.set(k, 'x', simX[i,:])
            if k==0:
                ocp_solver.set(k, 'u', uinit)
            else:
                ocp_solver.set(k, 'u', simU[i,:])
        ocp_solver.set(N, 'x', simX[i,:])
        #ocp_solver.set(0, "lbx", xcurrent)
        #ocp_solver.set(0, "ubx", xcurrent)
        # solve ocp and get next control input
        ocp_solver.solve_for_x0(x0_bar = simX[i, :])
        u = ocp_solver.get(0, "u")
        simU[i,:] = u
        #print("control at time", i, ":", u)
        #print("state at time", i, ":", simX[i, :])
        print("cost at time",i,":",ocp_solver.get_cost())
        print("sqp iters:", ocp_solver.get_stats('sqp_iter'))
        #ocp_solver.print_statistics()
        ocp_solver.reset()
        # simulate system
        simX[i+1, :]  = simulate_discrete_model(Ts,simX[i,:],u,nx)
    plot_multi_robots(simX)
if __name__ == '__main__':
    main()
Here are the model dynamics file and the plot function :
import sys
from utils import *
def simulate_discrete_model(Ts,x,u,nx):
    # simulation options
    m = 0.5
    Aid = np.array([[1,0,Ts,0],[0,1,0,Ts],[0,0,1,0],[0,0,0,1]])
    Ad = block_diag(Aid,Aid,Aid)
    Bid = np.array([[0,0],[0,0],[Ts/m,0],[0,Ts/m]])
    Bd = block_diag(Bid,Bid,Bid)
    x = Ad @ x + Bd @ u #+ np.random.normal(0, 0.01, (nx,))
    return x
from matplotlib import animation
from IPython.display import HTML
def plot_multi_robots(X):
    print("in plot funcion: ",X.shape)
    x1 = X[:, 0]
    y1 = X[:, 1]
    x2 = X[:, 4]
    y2 = X[:, 5]
    x3 = X[:, 8]
    y3 = X[:, 9]
    # create a figure and axes
    fig = plt.figure(figsize=(12, 5))
    ax1 = plt.subplot()
    # ax2 = plt.subplot(1,2,2)
    # set up the subplots as needed
    ax1.set_xlim((0, 12))
    ax1.set_ylim((0, 12))
    ax1.set_xlabel('x')
    ax1.set_ylabel('y')
    # create objects that will change in the animation. These are
    # initially empty, and will be given new values for each frame
    # in the animation.
    txt_title = ax1.set_title('')
    pt1, = ax1.plot([], [], 'g.', ms=20)
    line1, = ax1.plot([], [], 'y', lw=2)
    pt2, = ax1.plot([], [], 'g.', ms=20)
    line2, = ax1.plot([], [], 'y', lw=2)
    pt3, = ax1.plot([], [], 'g.', ms=20)
    line3, = ax1.plot([], [], 'y', lw=2)
    plt.plot(goal[0], goal[1], 'b*', ms=10)
    plt.plot(goal[4], goal[5], 'b*', ms=10)
    plt.plot(goal[8], goal[9], 'b*', ms=10)
    #plt.show()
    # animation function. This is called sequentially
    X1plot =[]
    Y1plot=[]
    X2plot =[]
    Y2plot=[]
    X3plot =[]
    Y3plot=[]
    def drawframe(n):
        X1plot.append(x1[n])
        Y1plot.append(y1[n])
        line1.set_data(X1plot[0:n+1],Y1plot[0:n+1])
        pt1.set_data(X1plot[n],Y1plot[n])
        X2plot.append(x2[n])
        Y2plot.append(y2[n])
        line2.set_data(X2plot[0:n+1],Y2plot[0:n+1])
        pt2.set_data(X2plot[n],Y2plot[n])
        X3plot.append(x3[n])
        Y3plot.append(y3[n])
        line3.set_data(X3plot[0:n+1],Y3plot[0:n+1])
        pt3.set_data(X3plot[n],Y3plot[n])
        txt_title.set_text('Frame = {0:4d}'.format(n))
        return (pt1,line1,pt2,line2,pt3,line3)
    anim = animation.FuncAnimation(fig, drawframe, frames=100, interval=100, blit=True,repeat=False)
    HTML(anim.to_html5_video())
    anim.save('ANIMATION.gif', writer='pillow', fps=60)
Thank you very much in advance!
Probably, the QP is infeasible then.
Did you look in other places in the forum?
https://discourse.acados.org/search?q=status%203
E.g.
Thank you for your quick reply!
Yes I have looked at other examples in the forum, but the solutions proposed never solved my problem. So I concluded that indeed the problem was infeasible. I actually indicated only go-to points, which makes the problem very hard to solve. But then, I computed some references trajectories (with a MPC with cost on collision avoidance and not hard constraints), and I used the first MPC to track these trajectories respecting the safety constraints. And it works better!
