OCP solver crashes with specific combination
I am not sure if it is user error or really a bug. But through my testing, I found that the combination of algebraic variables, nonlinear constraints, and a globalization option other than ‘FIXED_STEP’ causes the ocp_solver to crash when calling ‘solve()’.
I am using Matlab R2021a on Windows. I have installed Acados following the instruction on webpage; therefore the compiler is MinGW provided by MathWorks. I hope the following fulfills the requirement of a minimal example.
P. S. The crashes are mostly silent. However, at one point during testing with Simulink, I received an “Access violation detected” message from the MathWorks Crash Reporter. I believe this is related to the same issue. (It crashes immediately after pressing play.)
clear all;
check_acados_requirements()
%% Model
% states
x1 = casadi.MX.sym('x1');
% derivates
x1_dot = casadi.MX.sym('x1_dot');
% control
u1 = casadi.MX.sym('u1');
% algebraic variables
z1 = casadi.MX.sym('z1');
% function
eq1 = z1 - x1 + u1 - x1_dot;
eq2 = x1 + z1;
f = vertcat(eq1, eq2);
% So x_dot = -2*x1 + u1
% for constant u and x(0) = 0 -> x(t) = u/2 (1 - exp(-2t))
% Create Acados Model
model = AcadosModel();
model.x = x1;
model.xdot = x1_dot;
model.u = u1;
model.z = z1;
model.f_impl_expr = f;
%% OCP
% Create Acados OCP
ocp = AcadosOcp();
ocp.model = model;
% cost
ocp.cost.cost_type_0 = 'NONLINEAR_LS';
ocp.cost.W_0 = 1;
ocp.cost.yref_0 = 0; % for initialization only
ocp.model.cost_y_expr_0 = ocp.model.x;
ocp.cost.cost_type = 'NONLINEAR_LS';
ocp.cost.W = 1;
ocp.cost.yref = 0;
ocp.model.cost_y_expr = ocp.model.x;
ocp.cost.cost_type_e = 'NONLINEAR_LS';
ocp.cost.W_e = 1;
ocp.cost.yref_e = 0;
ocp.model.cost_y_expr_e = ocp.model.x;
% initial state constraint
ocp.constraints.x0 = 0; % required for setting initial states
% constraints on u
% ocp.constraints.constr_type_0 = 'BGH'; % is default
% ocp.constraints.constr_type = 'BGH'; % is default
% ocp.constraints.constr_type_e = 'BGH'; % is default
% ocp.constraints.idxbu = 0; % zero-based indices even for Matlab!
% ocp.constraints.lbu = -3;
% ocp.constraints.ubu = 3;
% bounds on initial
ocp.constraints.lh_0 = -3.2;
ocp.constraints.uh_0 = 3.2;
ocp.model.con_h_expr_0 = ocp.model.u;
% bounds on path
ocp.constraints.lh = -3.2;
ocp.constraints.uh = 3.2;
ocp.model.con_h_expr = ocp.model.u;
% no bounds on u at terminal node
% define solver options
ocp.solver_options.N_horizon = 10;
ocp.solver_options.tf = ocp.solver_options.N_horizon * 0.1;
ocp.solver_options.integrator_type = 'IRK';
ocp.solver_options.globalization = 'MERIT_BACKTRACKING';
% create solver
%% Test
% input
ocp_solver.set('constr_x0', 0);
ocp_solver.set('cost_y_ref', 1);
ocp_solver.set('cost_y_ref_e', 1);
% solve
ocp_solver.solve();
status = ocp_solver.get('status'); % 0 - success
% output
utraj = ocp_solver.get('u');
xtraj = ocp_solver.get('x');
unfortunately, it seems that both globalization strategies are not compatible with algebraic variables yet.
On Linux, an error message is printed in the terminal.
However, this unfortunately does not happen on Windows in MATLAB.
I will implement a check soon and create an issue that we should support this.
