Hi there!
Just followed the instructions for the installation process of acados ( https://docs.acados.org/installation/index.html -> Windows). After following all steps as described, I tried to start the minimal_example_ocp.m
(matlab).
I got the following Error:
Error using mex
MEX cannot find library 'acados', specified with the -l option.
MEX searched for a file with one of the following names:
libacados.a
acados.lib
libacados.lib
Verify the library name is correct. If the library is not
on the existing path, specify the path with the -L option.
Error in ocp_compile_interface (line 188)
mex(mex_flags, FLAGS, LDFLAGS, acados_include, acados_interfaces_include, external_include, blasfeo_include, hpipm_include,...
Error in acados_ocp (line 164)
ocp_compile_interface(obj.opts_struct);
Error in minimal_example_ocp (line 105)
I attached the CMakeCache.txt
which was created during the building process. I have tried diffrent option changes in CMakeLists. The latest version is attached. (edit:link in next post, because I am a new user)
In ocp_compile_interface.m
the code is searching for the ‘lib’-folder. But actually I saw that it was not built. Do I need to change something in the options?
Thanks a lot for your help! Please do not hesitate to ask for more information - since I am not familiar with building etc. the information might seem incomplete for you.
Best regards
Björn
System
Windows 10
Matlab R2019b
CMake 3.19.4
MinGW (as add-on in Matlab) 19.2.0
