Hi!
Thank you for adding getters for slack variables for Matlab. As in the example, ~/acados/examples/acados_matlab_octave/getting_started/extensive_example_ocp.m the code for getting slack variable values looks like,
% get slack values
for i = 0:N-1
sl = ocp.get(‘sl’, i);
su = ocp.get(‘su’, i);
t = ocp.get(‘t’, i);
sl = ocp.get(‘sl’, N);
su = ocp.get(‘su’, N);
I am afraid that this is probably wrong, because the index in Matlab cannot start from 0 in the for loop. When I run the code, I get empty sl and su of dimension 0x1. This is unusual for Matlab. Moreover, if you are running the loop to get slack values for the horizon, then it should be filled in a matrix instead of rewriting over the same variable sl and su. The correct code could look something like this in my opinion If n_executions>0 :
for i=1:n_executions
% get slack values
for i = 1:N-1
sl(:, i, n_executions) = ocp.get(‘sl’, i);
su(:, i, n_executions) = ocp.get(‘su’, i);
t(:, i, n_executions) = ocp.get(‘t’, i);
sl(:, N, n_executions) = ocp.get(‘sl’, N);
su(:, N, n_executions) = ocp.get(‘su’, N);end
One more thing, it is possible to get sl and su values individually. But we set values of only Z, z, Z_e and z_e and not Z_l, Z_u, z_l, z_u .... Should the dimension of Z and Z_e be adjusted according to sl and su or I am over-complicating this?
Does sl_e and su_e correspond to sl(N) and su(N)?
It would be really helpful if you can look into the issue. If there is something I misunderstood, then please guide me ![]()
Smit
