I’m using the Matlab Interface on MacOs.
I followed the installation process https://docs.acados.org/installation/index.html#windows-for-use-with-matlab , which goes smoothly, however when I try to run simulink example I get
found compiled acados MEX interface
Error using acados_ocp
Exception:
MATLAB:mex:ErrInvalidMEXFile
Invalid MEX-file
then i get:
Library not loaded: ‘@rpath/libacados.dylib’
The Matlab version I’m working on is the latest one, Matlab 2022b. I tried installing acids for a second time and I’m doing every step of the installation, but the problem persists. The macOs version is Monterrey 12.6.
Thanks a lot,
Lourdes
