Thank you for providing the powerful ACADOS!
Using acados python to implement the MPC algorithm for online linear model adaptive update. For discrete time linear models x_{t+1}=A x_t+B u_t, A and B will be continuously updated during operation, but when solving the iterative prediction within the prediction time domain N_p at each time step, it can be regarded as if A B within the prediction time domain is unchanged. How to modify A and B in MPC online?
I have test the code as follows:
model.x = MX.sym('x', model.nx)
model.u = MX.sym('u', model.nu)
model.y = MX.sym('y', model.ny)
model.A = MX.sym('A', model.nx, model.nx)
model.B = MX.sym('B', model.nx, model.nu)
model.name = 'linear_discrete_system_varying_AB'
model.p = vertcat(model.A.reshape((-1, 1)), model.B.reshape((-1, 1)))
model.disc_dyn_expr = model.A @ model.x + model.B @ model.u
And I get an error message,
File ~/demo/Adaptive-koopman/control_files/acados_mpc.py:165, in MPCControllerAcados.construct_controller(self)
163 # Compile acados OCP solver if necessary
164 json_file = f'acados_ocp_{self.model.name}.json'
--> 165 self.acados_solver = AcadosOcpSolver(ocp, json_file=json_file)
166 print("ACADOS MPC controller is constructed.")
File ~/acados/interfaces/acados_template/acados_template/acados_ocp_solver.py:234, in AcadosOcpSolver.__init__(self, acados_ocp, json_file, simulink_opts, build, generate, cmake_builder, verbose, save_p_global)
232 if json_file is not None:
233 acados_ocp.json_file = json_file
--> 234 self.generate(acados_ocp, json_file=acados_ocp.json_file, simulink_opts=simulink_opts, cmake_builder=cmake_builder, verbose=verbose)
235 json_file = acados_ocp.json_file
236 else:
File ~/acados/interfaces/acados_template/acados_template/acados_ocp_solver.py:120, in AcadosOcpSolver.generate(cls, acados_ocp, json_file, simulink_opts, cmake_builder, verbose)
117 acados_ocp.simulink_opts = simulink_opts
119 # make consistent
--> 120 acados_ocp.make_consistent(verbose=verbose)
1020 if self.p_global_values.shape[0] != dims.np_global:
ValueError: inconsistent dimension np, regarding model.p and parameter_values.
Got np = 340, self.parameter_values.shape = 0
Thanks for any suggestion!
