Hi!
I’m having some trouble with nonlinear constraints.
I want to limit the magnitude of 2D velocity and acceleration ( V_x^2 + V_y^2 < V_max^2), but the SQP solver fails.
When I set constraints on each axis separably, the solver works as expected.
I created a small example in Matlab to demonstrate the problem:
import casadi.*
%% system dimensions
nx = 6;
nu = 2;
%% named symbolic variables
position_error = SX.sym('position_error', 2); % Xt - Xi
Vi = SX.sym('Vi',2);
Vt = SX.sym('Vt',2);
acc = SX.sym('acc',2);
%% (unnamed) symbolic variables
sym_x = vertcat(position_error, Vi, Vt);
sym_xdot = SX.sym('xdot', nx);
sym_u = acc;
%% dynamics
expr_f_expl = vertcat(Vt - Vi, acc, [0,0]');
expr_f_impl = expr_f_expl - sym_xdot;
%% constraints
expr_h = [Vi(1)^2 + Vi(2)^2, acc(1)^2 + acc(2)^2]';
% When this is used, the solver works as expected
% expr_h = [Vi(1), Vi(2), acc(1), acc(2)]';
expr_h_e = [Vi(1), Vi(2)]';
W = eye(2);
W_e = diag([0,0]);
% Map state to y (y consists only of position error)
Vx = zeros(2,6);
Vx(1,1) = 1;
Vx(2,2) = 1;
Vx_e = zeros(2,6);
Vx_e(1,1) = 1;
Vx_e(2,2) = 1;
% Map inputs to y
Vu = zeros(2,2);
model = acados_ocp_model();
%% populate structure
model.model_struct.nx = nx;
model.model_struct.nu = nu;
model.model_struct.sym_x = sym_x;
model.model_struct.sym_u = sym_u;
model.model_struct.expr_f_expl = expr_f_expl;
model.model_struct.expr_f_impl = expr_f_impl;
model.model_struct.constr_expr_h = expr_h;
model.model_struct.constr_expr_h_e = expr_h_e;
model.model_struct.cost_W= W;
model.model_struct.cost_W_e= W_e;
model.model_struct.cost_type = 'linear_ls';
model.model_struct.cost_type_e = 'linear_ls';
model.model_struct.cost_Vu = Vu;
model.model_struct.cost_Vx = Vx;
model.model_struct.cost_Vx_e = Vx_e;
%% discretization
N = 50;
T = 5;
Xt_0 = [200, 400];
Vt = [-1,-1];
Xi_0 = [0, 0];
Vi_0 = [0, 0];
x0 = horzcat(Xt_0 - Xi_0, Vi_0, Vt);
nlp_solver = 'sqp'; % sqp, sqp_rti
qp_solver_cond_N = 5; % for partial condensing
% integrator type
sim_method = 'erk'; % erk = explicit Runge Kutta, irk = implicit Runge Kutta, irk_gnsf
%% model dynamics
ocp_model = model;
nx = ocp_model.model_struct.nx;
nu = ocp_model.model_struct.nu;
max_velocity_xy = 30;
max_acc_xy = 4;
ocp_model.model_struct.constr_lh = [0, 0]';
ocp_model.model_struct.constr_uh = [max_velocity_xy^2, max_acc_xy^2]';
% ocp_model.model_struct.constr_lh = [-30,-30, -4, -4]';
% ocp_model.model_struct.constr_uh = [30,30, 4, 4]';
ocp_model.model_struct.constr_lh_e = [-30,-30]';
ocp_model.model_struct.constr_uh_e = [30,30]';
% update initial state
% dynamics
if (strcmp(sim_method, 'erk'))
ocp_model.set('dyn_expr_f', ocp_model.model_struct.expr_f_expl);
else % irk irk_gnsf
ocp_model.set('dyn_type', 'implicit');
ocp_model.set('dyn_expr_f', ocp_model.model_struct.expr_f_impl);
ocp_model.model_struct.T = T;
%% acados ocp set opts
ocp_opts = acados_ocp_opts();
ocp_opts.set('qp_solver_cond_N', qp_solver_cond_N);
ocp_opts.set('ext_fun_compile_flags', ''); % '-O2'
y_ref = [0,0]; % Bring the position error to 0
y_ref_e = [0,0];
ocp_model.set('cost_y_ref', y_ref);
ocp_model.set('cost_y_ref_e', y_ref_e);
ocp.set('constr_lbx', x0, 0);
ocp.set('constr_ubx', x0, 0);
x_traj_init = zeros(nx, N+1);
x_traj_init(1,:) = x0(1);
x_traj_init(2,:) = x0(2);
x_traj_init(3,:) = x0(3);
x_traj_init(4,:) = x0(4);
x_traj_init(5,:) = x0(5);
x_traj_init(6,:) = x0(6);
u_traj_init = ones(nu, N);
% set trajectory initialization
ocp.solve();
switch ocp.get('status')
case 0
ocp.print('stat')
case 1
error('Failed: Detected NAN');
case 2
error('Failed: Maximum number of iterations reached');
case 3
error('Failed: Minimum step size in QP solver reached');
case 4
error('Failed: QP solver failed');
% get solution
u_result = ocp.get('u');
x_result = ocp.get('x');
Thanks in advance!
