I am currently getting started with acados and tried to run and understand some of the examples.
I am working with acados in C++ in the eclipse CDT IDE on a windows machine with the MinGW compiler.
I never worked with Gnuplot so excuse me if my question is not so intelligent.
I ran the code “discrete_time_rocket.cpp”. The following error appeared at the end on the console:
unrecognized option -background
line 0: Cannot load input from 'white'
Then the execution stopped and no gnuplot window opened.
I am sure that the pipe to gnuplot works and my program is able to open it, because with a modified “gnuplot_window.cpp” file gnuplot opened and showed the graphs.
I changed
gnuPipe = popen("gnuplot -persist -background white", "w");
in line 126 to:
gnuPipe = popen("gnuplot -persist", "w");
However plotting with multiple plots became weird and the figures were distorted. I really don´t know why because I couldn´t find any information on the -background white option on the internet.
A single figure in a window worked fine.
I would really appreciate if someone knows a solution how I could run gnuplot properly or just explain to me what this -background white phrase does.
Thanks a lot for your help!
Dana
