Constraints and Parameters for Specific Time-Steps, external?
Hi everyone,
Here I come again with a question regarding the acados problem formulation.
So far, I happily found that I can use external dynamics and costs from CasADi functions, which is great! Now, a perhaps harder question comes to mind:
  1. Is it possible to specify constraints that are active only in specific steps of the Receding Horizon (RH)? The closes I found was this thread, in particular, ocp.set('cost_y_ref', yr, i) seems to set the parameter for horizon i, so I could do the same with ocp.set('lbx', bnd, i) to set the lower bound for X at stage i ? How does the interface work?
  2. In the same way, is it possible to set external parameters to be used in specific RH steps?
Thanks a lot!
Pedro,
Hi Pedro,
I guess you are still using Python?
So the equivalent in Python to the Matlab snippet you posted
would be this:
acados_ocp_solver.constraints_set(stage, "lbx", lbx)
The functions how to interact with AcadosOcpSolver are documented here: https://docs.acados.org/interfaces/#acados_template.acados_ocp_solver.AcadosOcpSolver
Setting parameters for individual stages works like this:
acados_ocp_solver.set(stage, "p", p_value)
Thanks Jonathan!
So it seems I can just use “p” as a parameter array that then is updated for each stage of the horizon (and in a default manner, initalize it before solving the problem). So the last question is just if I can use these parameters with external cost functions (to use a state-reference for instance)?
Pedro,
Sure, you can use external cost functions with parameters.
However, if you have a state reference in the cost, you can most likely formulate your problem more efficiently with a linear or nonlinear leas-squares cost function and update yref.
In my case, the cost is not just || x - xr|| , since the way we calculate the error between two quaternions is nonlinear (atm I convert them to R matrices and use Lee’s equations, but also plan on avoiding that). Unless we use euler, I don’t see an easy way to calculate the attitude error using least squares
I’ll take a look at those parameters sometime soon, and will report back.
Pedro
