I am planning to use a map representation with custom gradients in my MPC problem, that cannot be formulated in the casadi syntax.
I therefore tried to express it in casadi’s C API, that is also used when generating C code from casadi expressions.
This C code can then be compiled to a shared object file and imported back using
f = external("f", "f.so")
Unfortunately using cost expressions obtained in this way does seem to be supported with acados “external” cost functions.
I provided a minimal example below. Note that the C Code generation is only for demonstration and reproduction purposes and cannot be used in my application, since the casadi syntax cannot express my problem.
Code Generation:
from casadi import *
x = MX.sym("x", 2, 1)
f = MX.sym("f", 1, 1)
df = MX.sym("df", 1, 2)
generator = CodeGenerator("cost.c")
cost = Function("cost", [x], [x.T @ x])
jac_cost = Function("jac_cost", [x, f], [jacobian(cost(x), x)])
hess_cost = Function("jac_jac_cost", [x, f, df], [hessian(cost(x), x)[0], hessian(cost(x), x)[1]])
generator.add(cost)
generator.add(jac_cost)
generator.add(hess_cost)
generator.generate()
import subprocess
import time
subprocess.Popen('gcc -fPIC -shared cost.c -o cost.so', shell=True)
time.sleep(0.5)
c = external("cost", "cost.so")
j = Function("first_derivative",[x], [jacobian(c(x), x)])
h = Function("second_derivative",[x], [hessian(c(x), x)[0]])
point = np.array([1,1])
print(c(point))
print(j(point))
print(h(point))
Acados MPC Script:
from acados_template import AcadosOcp, AcadosOcpSolver, AcadosModel
import casadi as cas
import time
import control
import sympy as sp
from scipy.linalg import expm
A_c = np.array([[0, 1], [0, 0]])
B_c = np.array([[0], [1]])
T_s = 0.033
A_d = expm(A_c * T_s)
tau =sp.symbols('tau')
B_d = np.array(sp.integrate(sp.exp(sp.Matrix(A_c) *(T_s - tau)) @ sp.Matrix(B_c), (tau, 0, T_s))).astype(np.float64)
nx = A_d.shape[0]
nu = B_d.shape[1]
print("nx:", nx)
print("nu:", nu)
N = 500
dt = T_s
Q = np.eye(nx)
R = np.eye(nu)
K, P, _ = control.dlqr(A_d, B_d, Q, R)
x0 = np.array([10.0, 0.0])
umin = -10
umax = 10
x = cas.MX.sym('x', (nx,1))
u = cas.MX.sym('u', (nu,1))
x_next = cas.mtimes(A_d, x) + cas.mtimes(B_d, u)
model.x = x
model.u = u
model.disc_dyn_expr = x_next
model.name = "linear_mpc"
ocp.dims.N = N
ocp.solver_options.tf = N * dt
y = cas.MX.sym('y', nx)
x_cost = cas.Function("cost",[y], [y.T @y])
x_cost_e = cas.external('cost', 'cost.so')
cost = x_cost(x)+ u.T @ R @ u
cost_e = x_cost_e(x) # TODO: Change to x_cost(x) to make it work again
ocp.model.cost_expr_ext_cost = cost
ocp.model.cost_expr_ext_cost_e = cost_e
ocp.constraints.lbu = np.ones((nu, )) * umin
ocp.constraints.ubu = np.ones((nu, )) * umax
ocp.constraints.idxbu = np.array(range(nu))
ocp.constraints.x0 = x0
ocp.solver_options.hessian_approx = 'EXACT'
ocp.solver_options.integrator_type = 'DISCRETE'
x = x0
n_sim = 300
ts = np.linspace(0, n_sim * dt, n_sim +1)
solve_times = []
x_history = [x]
u_history = []
for _ in range(n_sim):
ocp_solver.set(0, 'lbx', x)
ocp_solver.set(0, 'ubx', x)
start = time.time()
status = ocp_solver.solve()
end = time.time()
solve_times.append(end - start)
if status != 0:
print(f"Solver failed with status {status}")
u_opt = ocp_solver.get(0, 'u')
u_history.append(u_opt)
x = A_d @ x + B_d @ u_opt
x_history.append(x)
x_history = np.array(x_history)
u_history = np.array(u_history)
solve_times = np.array(solve_times)
print(f"Average solve time: {np.mean(solve_times)}")
print(f"Average Hertz: {1/np.mean(solve_times)}")
print(f"Max solve time: {np.max(solve_times)}")
# Plot results
plt.figure()
plt.plot(ts,x_history)
plt.title("State Trajectory")
plt.xlabel("Seconds")
plt.ylabel("States")
plt.legend(["x1", "x2"])
plt.grid()
plt.figure()
plt.step(ts[:-1], u_history)
plt.title("Control Input")
plt.ylabel("u")
plt.legend(["u1"])
plt.grid()
plt.show()
The execution of this results in the following error.
linear_mpc_cost_ext_cost_e_fun_jac.c:(.text+0x160): multiple definition of `casadi_f0_decref'; linear_mpc_cost/linear_mpc_cost_ext_cost_e_fun.o:linear_mpc_cost_ext_cost_e_fun.c:(.text+0xe0): first defined here
collect2: error: ld returned 1 exit status
followed by
OSError: /xxx/c_generated_code/libacados_ocp_solver_linear_mpc.so: cannot open shared object file: No such file or directory
Is it planned to support importing casadi compiled functions in the future?
If not, could you comment on the feasibility of implementing this and maybe point me in the right direction?
Thanks for your help and the amazing work on acados ![]()
Mario
