Add a constraint on cost value
I’m using python with external cost and IRK integrator.
I would like to define a constraint on the whole solution cost value rather than on a horizon step.
Based on the Problem Formulation PDF it doesn’t seem to be possible. But it is needed for some formulations.
One of my ideas was to set it as a terminal constraint, by accumulating the costs on the path to get the same value as get_cost(). But I didn’t manage to setup a variable to store and update the accumulated cost value along the path.
I’ve tried to put it in the state, but realized that it will be integrated, and so I wouldn’t get Jk+1 = h * l(x,u) + Jk.
Any help would be appreciated,
Rémi
Hi :waving_hand:
you can use discrete dynamics, i.e. you provide a function x_{k+1} = f(x_k, u_k). This allows you to add the cost terms. But you will then need to define the integrator for the other states yourself.
Hope this helps,
Katrin
Thank you for your answer,
I’ve implemented a rk4 for the other states. I haven’t compared the accuracy with IRK integrator yet, but it seems to work well.
