I am trying to understand how to use the acados templated mex solver by running the test file “run_test_template_ocp_linear_dae.m” and I got the following error:
Error using mex
MEX cannot find library 'acados_ocp_solver_toy_dae2', specified with the -l option.
MEX searched for a file with one of the following names:
libacados_ocp_solver_toy_dae2.a
acados_ocp_solver_toy_dae2.lib
libacados_ocp_solver_toy_dae2.lib
Verify the library name is correct. If the library is not
on the existing path, specify the path with the -L option.
Error in make_mex_toy_dae2 (line 104)
mex(FLAGS, acados_include, template_lib_include, external_include,
blasfeo_include, hpipm_include,...
Error in toy_dae2_mex_solver (line 49)
make_mex_toy_dae2();
Error in test_template_ocp_linear_dae (line 228)
eval( command );
It seems that the mex function cannot find the right library file. I attached a print of this folder where there is a file called “libacados_ocp_solver_toy_dae2.so”. I am using the Matlab 2019b with Casadi 3.5.5 in Windows 10.
Can you help me to solve this issue?
Best regards,
Paulo
However, currently Matlab just doesn’t launch on my Windows and I have other priorities than working on that.
Equivalence of the native MEX solver and template based one can be checked on Linux. The test you mentioned is run on Github Actions.
The template based solver, can be used on Windows only via Simulink for now.
