I’m using python to solve NONLINEAR_LS cost functions for a continuous quadrotor system. My original setup works well, but now I’m going to add a time varying offset for further testing.
I plan add an offset for self.u (i.e., f_thrust) only to some stages (e.g., the first stage) of the model below, so I wonder how I can do this. I found a post Change model parameters - User Questions - acados forum that mentioned <model_name>_acados_update_params, but I cannot find the detailed usage anywhere.
Is there any instructions to update system dynamics like this? Thanks!
def quad_dynamics(self):
x_dot = cs.vertcat(self.x_dynamics(), self.v_dynamics(), self.q_dynamics(), self.w_dynamics())
return cs.Function('x_dot', [self.x[:13], self.u], [x_dot], ['x', 'u'], ['x_dot'])
def x_dynamics(self):
return self.v
def q_dynamics(self):
return 1 / 2 * cs.mtimes(skew_symmetric(self.w), self.q)
def v_dynamics(self):
f_thrust = self.u
g = cs.vertcat(0.0, 0.0, self.g)
ind = True
if ind:
a_thrust = cs.vertcat(0.0, 0.0, f_thrust[0]+f_thrust[1]+f_thrust[2]+f_thrust[3]) / self.quad_mass
else:
a_thrust = cs.vertcat(0.0, 0.0, f_thrust[0]) / self.quad_mass
v_dynamics = v_dot_q(a_thrust, self.q) - g
return v_dynamics
def w_dynamics(self):
f_thrust = self.u
ind = True
if ind:
TM = f_to_TM(f_thrust, True)
tau_b = cs.vertcat(TM[1], TM[2], TM[3])
else:
tau_b = cs.vertcat(f_thrust[1], f_thrust[2], f_thrust[3])
tmp = tau_b - cs.cross(self.w, cs.mtimes(self.J, self.w))
return cs.mtimes(self.inv_J, tmp)
