Soft constraints in Acados
I want to use soft constraints in Acados. I think I understand how to set them. However, what I am missing is how to set the multiplier/penalty term in the objective function for the slack variables. In the acados paper there are mentioned alpha and beta as multiplier but I can not find them in the Python API. How do I set these multipliers?
Do the soft constraints also work with the external cost function?
Thanks,
David
You can take a look at the Zu, Zl, zu, zl, Zu_e, Zl_e, zu_e, zl_e terms in the documentation of python interface. The corresponding math formulation is well explained here:
acados/problem_formulation_ocp_mex.pdf at master · acados/acados (github.com).
From my experience, yes.
Fenglong
Hey Fenglong,
thank you very much for the quick answer. I was looking for such a document long ago!
Thanks,
David
