Simple QP implementation
Hi all,
I have been using ACADOS for a while and have an SQP problem formulation which I have working on some embedded hardware via the (extremely useful) Simulink interfaces.
For a few reasons (which I wont go in to) I want to compare this model to a linearised version using a vanilla QP on the embedded hardware - and I would ideally like to do this using the ACADOS Simulink interfaces.
I already have an implementation of the QP using the HPIPM toolbox so I know this is all working.
My question is: Is it possible/simple to get ACADOS to do just the QP step using the equivalent of HPIPMs OCP problem formulation? My attempts so far have not been fruitful.
Thanks,
Will.
acados does not have a Simulink interface for QP solvers.
I suggest to just phrase a QP as an OCP NLP and just use solve that with acados.
i.e. use linear discrete dynamics, quadratic cost and linear constraints.
Thanks for the reply.
I tried that and found that I do not converge to the same solution as the QP with the same formulation - probably what you would expect, although I was a bit surprised it doesn’t converge to the optimal solution given the linear nature of the problem.
I guess I will have to be content with what it gives me.
Will.
