I am trying to implement a reference trajectory y-ref for a linear cost function.
i have defined the following
ocp = acados_ocp(ocp_model,ocp_opts);
for i = 0:N-1
current_r_ref = [r_ref(:, i+1);0;0]; % Get the reference for the current timestep
ocp.set('cost_y_ref',i,current_r_ref); % Set the parameter 'p' for timestep 'i-1' (acADOS uses zero indexing)
where current_r_ref has the size of ny x 1. But I get the following error.
Error using acados_mex_set_obsRT
ocp_set: field cost_y_ref not supported for cost type 4 at stage -40
Error in obsRT_mex_solver/set (line 89)
acados_mex_set_obsRT(obj.cost_ext_fun_type, obj.cost_ext_fun_type_e, obj.C_ocp, field, value, stage);
Error in acados_ocp/set (line 243)
obj.t_ocp.set(field, value, varargin{:});
Error in RT_obs_acados_R1 (line 175)
Any help appreciated.
Thanks,
