Setting parameters for terminal costs / constraints
how should one set parameters for the terminal stage of optimization? My first assumption was
for ii = 0 : (N - 1)
    ocp.set('p', p, ii);  // parameters for Lagrange objective
ocp.set('p', p, N);   // parameters for Mayer objective (terminal costs)
However, the last statement crashes Matlab if I use the cost module “ext_cost” (casadi expression). As a workaround I have to set the terminal parameters with
ocp.set('p', p);
before the loop, which is not very intuitive. Is this the intended workflow or is the Matlab crash a bug?
BR
Martin
Hi Martin,
there was indeed a bug, which I just fixed:
It is merged into acados/master.
Note that you have to recompile the Matlab interface, which can be done by removing the build folder in your example directory.
thanks for the quick fix.
Martin
