S-Function (qp solver failed =>init_u?)
Hello everyone,
Unfortunately, I am currently stuck at one point and would like to ask for your advice. (Matlab/Simulink Interface)
Problem: When simulating in Matlab (one trajectorie, as in “minimal_example” from “getting started”-Example), the simulation runs and the solver can find a final solution after a few steps (0, success in every step). If I now generate code and run the simulation in Simulink with the same input variables, the qp solver fails permanently (4).
Background info: Based on the “getting started” example, I have extended the pendulum model with constraints on x. I have prepared all settings for my model (Explicit. Added non-quadratic terms to the cost function =>external costs. NLP). Furthermore, I added parameters. Up to this point, everything works perfectly (incl. S-Function in Simulink).
I then replaced the pendulum model with my model. I still use an external cost function without terminal costs. After the first copy-paste battle, I also had a failed solver (4) in Matlab. However, this was because init_x and init_u were both still 0-vectors from the example. After I had replaced these with my actual initial states, the model ran in Matlab.
For Simulink, init_x can be added via the Simulink options (get_acados_simulink_opts), but init_u unfortunately cannot. Is this perhaps also the problem in Simulink? Do the initial vectors affect the codegen?
Side question: What is init_pi for? Unfortunately I have not found a lot on this.
Many thanks in advance, best regards
Björn
P.S. I am looking forward to the workshop next week!
Hi Björn,
This functionality is indeed missing for the Simulink interface.
It seems generally useful and important to make the solver converge for your problem.
I am going to add it later this week.
perfect, thank you!
Best regards,
Björn
I added the u_init port in this PR, which I plan to merge tomorrow:
Forgot to answer here:
pi: multipliers for dynamics equality constraints
This can be found here: https://docs.acados.org/python_api/index.html#acados_template.acados_ocp_solver.AcadosOcpSolver.get
