I’m using the Matlab Interface on a Windows 10.
I followed the installation process https://docs.acados.org/installation/index.html#windows-for-use-with-matlab, which goes smoothly, however when I try to run minimal_example_ocp I get
Building with 'MinGW64 Compiler (C)'.
MEX completed successfully.
Error using acados_ocp (line 189)
Exception:
MATLAB:mex:ErrInvalidMEXFile
Invalid MEX-file 'E:\tools\acadosNeu\acados\examples\acados_matlab_octave\getting_started\build\ocp_create.mexw64': The specified module could not be found.
Error in minimal_example_ocp (line 107)
Error in run (line 96)
evalin('caller', [script ';']);
It seems like the mex files are missing some dependencies to execute.
I’m working on a university lab computer, that uses Matlab 2016b (rather old), so I’m wondering if that’s causing the trouble - is there any known minimal Matlab requirement? (The installation guideline just says “recent”).
Thanks a lot!
Anne
