I made an MPC using Acados in Python now I’m trying to use the C-generated code in my C++ framework. I have few questions/problems.
To test the C++ implementation I’m comparing the solutions of the Python vs C++ starting from the same data. I noticed that if I don’t set the weights in both the solutions coincide, but when I try to set the weights the solutions differ. I already checked the values in the W matrix and they are the same. I assume I’m doing something wrong. To set the weight I’m using ocp_nlp_cost_model_set().
In Python the solver is by default warm started with past solution if no other values are set right? Is it the same in C++ ?
When I call the generated code from C++ do I need to specify the setting I already put in the python at compilation time or are they saved? (e.g. hpipm_mode, qp_solver_warm_start, regularize_method )
Thanks for the help
