Cannot execute minimal_example_ocp in matlab2023a in Windows10
I’m using acados with matlab2023a in Win10.
After automatic building of acados (minGW) following the guide in Installation — acados documentation , I run minimal_example_ocp and get the following Error:
Structure detection for path cost
Cost function is quadratic -> Reformulating as linear_ls cost.
reformulated cost term in linear least squares form with:
cost = 0.5 * || Vx * x + Vu * u + Vz * z - y_ref ||_W
Vx
     1     0     0     0
     0     1     0     0
     0     0     1     0
     0     0     0     1
     0     0     0     0
Vu
     0
     0
     0
     0
     1
Vz
W
   1.0e+03 *
    1.0000         0         0         0         0
         0    1.0000         0         0         0
         0         0    0.0000         0         0
         0         0         0    0.0000         0
         0         0         0         0    0.0000
y_ref
     0
     0
     0
     0
     0
y (symbolic)
[p, theta, v, dtheta, F]
NOTE: These numerical values can be updated online using the appropriate setters.
Structure detection for terminal cost term
Vx
     1     0     0     0
     0     1     0     0
     0     0     1     0
     0     0     0     1
Vu
     0
     0
     0
     0
Vz
W
   1.0e+03 *
    1.0000         0         0         0
         0    1.0000         0         0
         0         0    0.0000         0
         0         0         0    0.0000
y_ref
     0
     0
     0
     0
y (symbolic)
[p, theta, v, dtheta]
Constraint detection for path constraints.
constraint 1 is reformulated as bound on u.
F
found compiled acados MEX interface
Error using: acados_template_mex.compile_ocp_shared_lib
Building templated code as shared library failed.
Got status 2, result: [ 14%] Building C object
CMakeFiles/model_pendulum.dir/pendulum_model/pendulum_expl_ode_fun.c.obj
[ 28%] Building C object
CMakeFiles/model_pendulum.dir/pendulum_model/pendulum_expl_vde_forw.c.obj
[ 42%] Building C object
CMakeFiles/model_pendulum.dir/pendulum_model/pendulum_expl_vde_adj.c.obj
[ 42%] Built target model_pendulum
[ 57%] Building C object
CMakeFiles/ocp_pendulum.dir/pendulum_constraints/pendulum_constr_h_0_fun_jac_uxt_zt.c.obj
[ 71%] Building C object
CMakeFiles/ocp_pendulum.dir/pendulum_constraints/pendulum_constr_h_0_fun.c.obj
[ 85%] Building C object
CMakeFiles/ocp_pendulum.dir/acados_solver_pendulum.c.obj
[ 85%] Built target ocp_pendulum
[100%] Linking C shared library acados_ocp_solver_pendulum.dll
D:/acados/acados/examples/acados_matlab_octave/../../lib/acados.lib(timing.c.obj):timing.c:(.text+0x22):
undefined reference to `clock_gettime'
D:/acados/acados/examples/acados_matlab_octave/../../lib/acados.lib(timing.c.obj):timing.c:(.text+0x9):
mingw32-make.exe[2]: ***
[CMakeFiles\acados_ocp_solver_pendulum.dir\build.make:94:
acados_ocp_solver_pendulum.dll] Error 1
mingw32-make.exe[1]: *** [CMakeFiles\Makefile2:139:
CMakeFiles/acados_ocp_solver_pendulum.dir/all] Error 2
mingw32-make.exe: *** [Makefile:135: all] Error 2
Error: ocp_generate_c_code (第 281 行)
    acados_template_mex.compile_ocp_shared_lib(obj.acados_ocp_nlp_json.code_export_directory)
Error: acados_ocp (第 203 行)
            ocp_generate_c_code(obj);
Error: minimal_example_ocp (第 114 行)
Could you figure out how to fix it?
Thank you
clock_gettime should work on any modern system out of the box: linux - C++ error: undefined reference to 'clock_gettime' and 'clock_settime' - Stack Overflow
Although there seems to have been some issue with that timer and MinGW: Bug #1853168 “undefined reference to `clock_gettime'” : Bugs : EPICS Base
Could you try to find what MinGW version you have?
Also you could edit timing.c and timing.h to just return 0, if you want to use acados without timings.
a similar problem is reported here and is likely an issue of (some) mingw versions:
@yuhai, could you provide your version of MinGW?
a possible solution to this problem can be found here.
Kind regards,
Josip
