Hi Acados community,
I’m currently using the python acados interface and we are trying to write an MPC which regulates the zero moment point of a LIP. We use this as an approximation for our bipedal walker. From the MPC, we need to extract amongst others, the footstep positions and the CoM trajectory.
To impose certain constraints we also need the previous footsteps. Every time a new footstep is set, the old footstep positions have to be switched. One of the problems is that the footstep switch timing is not in line with with the MPC timing. Namely, the footsteps only have to be switched every 4 shooting nodes, not every single shooting node.
From what I have seen from other forum posts, the best way to tackle this is to put both the current footsteps and the previous footsteps in the state vector. The derivative of the previous footstep would be x_pos (current footstep) - x_pos_prev (prevous footstep). By passing a model parameter called “switch”, we make sure the derivative of the previous footstep is only calculated at the moment when a new footstep is set. The “switch” parameter is 1 for every 4 shooting nodes, and 0 for everything in between.
eta = np.sqrt(g/h_c)
f_expl = vertcat(dxcom,
(eta**2)*xcom-(eta**2)*xzmp,
dxzmp,
dycom,
(eta**2)*ycom-(eta**2)*yzmp,
dyzmp,
newstep_xdot,
-switch*xpos_prev+switch*xpos,
newstep_ydot,
-switch*ypos_prev-switch*ypos)
With newstep_xdot and newstep_ydot being the rate of change for the new footstep.
We hardcoded when i = 0 because the bipedal walker at that moment is in double stance, which has different dynamics from when it is in single stance. The periodic walking after taking of should correspond to:
elif i != 0 and i%(N/len(plan_footsteps[0]))==0:
index+=1
count = -count
ocp_solver.set(i, "p", np.array([plan_footsteps_delta[0], -count*plan_footsteps_delta[1], 1]))
With index going up our footstep reference planning and count switching the axis for the y positions, which need to be either +0.1 or -0.1.
Now that the problem formulation is described, our problem is that when we want to update the x_pos_prev and y_pos_prev, the values are not what we expect. x_pos and y_pos work perfectly but the x_pos_prev and y_pos_prev values don’t correspond to the previous footsteps. Does this have something to do with the integrator that is used?
The image shows the printed previous and current footsteps.
Can you please help us on what might be going wrong?
Thank you in advance!
Kind greetings,
Jack
