Recently, I use ACADO to solve the OCP of NMPC in Simulink. During the simulation, we receive the error information as follow “NMPC step (error value: 33)”. And, I don’t know how to check and remove the error. Could you give me some suggestion?
not sure if anyone can answer that here.
Is there a particular reason you are using ACADO instead of acados?
ACADO is not actively maintained since around 2018, see update README with note on current development and acados reference by FreyJo · Pull Request #304 · acado/acado · GitHub
Of course if anyone knows about ACADO, feel free to answer.
Thank your reply! I learned about the ACADOs when I first applied the optimizer, but because I couldn’t find a good code generation example, I applied the ACADO solver. Now, I don’t know to obtain the optimal solution. I am attaching my source code and the code generation code now, please help me check if there are any errors in the settings. Thank you very much!
EXPORT = 1;
DifferentialState LambdaF LambdaR BrakeTorF BrakeTorR;
Control DeltaTorF DeltaTorR;
OnlineData PedalTorqueF PedalTorqueR;
OnlineData Vx Ax MiuF MiuR;
%% System model
global VehicleModelParameter TireForce Control_Para
Wf = TireForce.Fzf;
Wr = TireForce.Fzr;
DFz = TireForce.DFz;
Rf = VehicleModelParameter.Rdius;
Rr = Rf;
Jf = VehicleModelParameter.Jw;
Jr = Jf;
Tao_f = VehicleModelParameter.Tao_f;
Tao_r = VehicleModelParameter.Tao_r;
Ts = 0.001;
N_Steps = Control_Para.Nsteps;
Phi_F = -RfMiuF(Wf - DFzAx) + Jf(1 - LambdaF)Ax/Rf;
Phi_r = -RrMiuR*(Wr + DFzAx) + Jr(1 - LambdaR)*Ax/Rr;
f = [dot(LambdaF) == Rf*(Phi_F + PedalTorqueF + DeltaTorF)/(JfVx);…
dot(LambdaR) == Rr(Phi_r + PedalTorqueR + DeltaTorR)/(Jr*Vx);…
dot(BrakeTorF) == (PedalTorqueF + DeltaTorF - BrakeTorF)/Tao_f;…
dot(BrakeTorR) == (PedalTorqueR + DeltaTorR - BrakeTorR)/Tao_r];
%% SIMexport
fprintf(‘-----------------------\n SIMexport \n-----------------------\n’);
acadoSet(‘problemname’,‘sim’);
sim = acado.SIMexport(Ts);
numSteps = 1;
sim.setModel(f);
sim.set(‘INTEGRATOR_TYPE’,‘INT_IRK_GL4’);
sim.set(‘NUM_INTEGRATOR_STEPS’,numSteps);
if EXPORT
sim.exportCode(‘export_sim’);
cd export_sim
make_acado_integrator(‘…/integrate_Brake’)
cd …
%% MPCexport
fprintf(‘-----------------------\n MPCexport \n----------------------\n’);
Opt_Vari = [LambdaF;LambdaR];
h = [Opt_Vari;controls];
hN = Opt_Vari;
W_mat = eye(length(h));
WN_mat = eye(length(hN));
W = acado.BMatrix(W_mat);
WN = acado.BMatrix(WN_mat);
ocp = acado.OCP( 0.0,N_Steps*Ts,N_Steps);
ocp.minimizeLSQ(W,h);
ocp.minimizeLSQEndTerm(WN,hN);
Slip_LB = 0.15;
Slip_UB = 0.3;
DeltaTorF_LB = -1000;
DeltaTorR_LB = -1000;
Control_Torque_UB = 0;
Wheel_Torque_UB = 2000;
Wheel_Torque_LB = 0;
% Constraints on control inputs
ocp.subjectTo(DeltaTorF_LB <= DeltaTorF <= Control_Torque_UB);
ocp.subjectTo(DeltaTorR_LB <= DeltaTorR <= Control_Torque_UB);
% Constraints on state variables (slip ratios)
ocp.subjectTo(Slip_LB <= LambdaF <= Slip_UB);
ocp.subjectTo(Slip_LB <= LambdaR <= Slip_UB);
% Constraints on Brake Torques
ocp.subjectTo(Wheel_Torque_LB <= BrakeTorF <= Wheel_Torque_UB);
ocp.subjectTo(Wheel_Torque_LB <= BrakeTorR <= Wheel_Torque_UB);
% Model definition is correct
ocp.setModel(f);
mpc = acado.OCPexport(ocp);
mpc.set(‘HESSIAN_APPROXIMATION’,‘GAUSS_NEWTON’);
mpc.set(‘QP_SOLVER’,‘QP_QPOASES’);
mpc.set(‘DISCRETIZATION_TYPE’,‘MULTIPLE_SHOOTING’);
mpc.set(‘HOTSTART_QP’,‘YES’);
mpc.set(‘LEVENBERG_MARQUARDT’,1e-1);
mpc.set(‘CG_HARDCODE_CONSTRAINT_VALUES’,‘NO’);
mpc.set(‘SPARSE_QP_SOLUTION’,‘FULL_CONDENSING’);
mpc.set(‘INTEGRATOR_TYPE’,‘INT_IRK_GL2’);
mpc.set(‘NUM_INTEGRATOR_STEPS’,N_Steps);
if EXPORT
mpc.exportCode( ‘export_mpc’ );
copyfile(‘F:\Matlab2022A\acado-master\external_packages\qpoases’,‘export_mpc/qpoases’)
cd export_mpc
make_sfunction(‘…/ABS_NMPC’)
cd …
#define S_FUNCTION_NAME ABS_NMPC
#define S_FUNCTION_LEVEL 2
#define MDL_START
extern “C” {
#include “acado_common.h”
#include “acado_auxiliary_functions.h”
#include “simstruc.h”
ACADOvariables acadoVariables;
ACADOworkspace acadoWorkspace;
static void mdlInitializeSizes (SimStruct S)
/ Specify the number of continuous and discrete states */
ssSetNumContStates(S, 0);
ssSetNumDiscStates(S, 0);
/* Specify the number of intput ports */
if ( !ssSetNumInputPorts(S, 5) )
return;
/* Specify the number of output ports */
if ( !ssSetNumOutputPorts(S, 4) )
return;
/* Specify the number of parameters */
ssSetNumSFcnParams(S, 7);
if ( ssGetNumSFcnParams(S) != ssGetSFcnParamsCount(S) )
return;
/* Specify dimension information for the input ports */
ssSetInputPortVectorDimension(S, 0, ACADO_NX);
ssSetInputPortVectorDimension(S, 1, ACADO_NY);
ssSetInputPortVectorDimension(S, 2, ACADO_NOD);
ssSetInputPortVectorDimension(S, 3, ACADO_NY*ACADO_NY);
ssSetInputPortVectorDimension(S, 4, ACADO_NYN*ACADO_NYN);
/* Specify dimension information for the output ports */
ssSetOutputPortVectorDimension(S, 0, ACADO_NU );
ssSetOutputPortVectorDimension(S, 1, 1 );
ssSetOutputPortVectorDimension(S, 2, ACADO_NX );
ssSetOutputPortVectorDimension(S, 3, 1 );
/* Specify the direct feedthrough status */
ssSetInputPortDirectFeedThrough(S, 0, 1);
ssSetInputPortDirectFeedThrough(S, 1, 1);
ssSetInputPortDirectFeedThrough(S, 2, 1);
ssSetInputPortDirectFeedThrough(S, 3, 1);
ssSetInputPortDirectFeedThrough(S, 4, 1);
/* One sample time */
ssSetNumSampleTimes(S, 1);
#if defined(MATLAB_MEX_FILE)
#define MDL_SET_INPUT_PORT_DIMENSION_INFO
#define MDL_SET_OUTPUT_PORT_DIMENSION_INFO
static void mdlSetInputPortDimensionInfo(SimStruct *S, int_T port, const DimsInfo_T *dimsInfo)
if ( !ssSetInputPortDimensionInfo(S, port, dimsInfo) )
return;
static void mdlSetOutputPortDimensionInfo(SimStruct *S, int_T port, const DimsInfo_T *dimsInfo)
if ( !ssSetOutputPortDimensionInfo(S, port, dimsInfo) )
return;
#endif /* MATLAB_MEX_FILE */
static void mdlInitializeSampleTimes(SimStruct *S)
double SAMPLINGTIME = mxGetScalar( ssGetSFcnParam(S, 0) );
ssSetSampleTime(S, 0, SAMPLINGTIME);
ssSetOffsetTime(S, 0, 0.0);
static void mdlStart(SimStruct *S)
int i, j, k;
InputRealPtrsType in_ref, ODInit;
// double *xInit, *uInit, *ODInit, *Smat, *SNmat, *numSteps, *lbV, *ubV, *lbAV, *ubAV;
double *xInit, *uInit, *Smat, *SNmat, *lbV, *ubV;
/* get inputs and perform feedback step */
in_ref = ssGetInputPortRealSignalPtrs(S, 1);
ODInit = ssGetInputPortRealSignalPtrs(S, 3);
xInit = mxGetPr( ssGetSFcnParam(S, 1) );
uInit = mxGetPr( ssGetSFcnParam(S, 2) );
// ODInit = mxGetPr( ssGetSFcnParam(S, 3));
for( i=0; i < ACADO_N+1; ++i ) {
for( j=0; j < ACADO_NX; ++j ) acadoVariables.x[i*ACADO_NX+j] = xInit[j];
for( i=0; i < ACADO_N; ++i ) {
for( j=0; j < ACADO_NU; ++j ) acadoVariables.u[i*ACADO_NU+j] = uInit[j];
for( j=0; j < ACADO_NY; ++j ) acadoVariables.y[i*ACADO_NY+j] = (double)(*in_ref[j]);
// for( i=0; i < ACADO_N+1; ++i){
// for( j=0, j < ACADO_NOD; ++j) acadoVariables.od[i*ACADO_NOD+j] = ODInit[j];
for( j=0; j < ACADO_NOD; ++j) acadoVariables.od[i*ACADO_NOD+j] = (double)(*ODInit[j]);
for( i=0; i < ACADO_NYN; ++i ) acadoVariables.yN[i] = (double)(*in_ref[i]);
// for( i=0; i < ACADO_NOD; ++i ) acadoVariables.od[i] = (double)(*ODInit[i]);
Smat = mxGetPr( ssGetSFcnParam(S, 3) );
SNmat = mxGetPr( ssGetSFcnParam(S, 4) );
// numSteps = mxGetPr( ssGetSFcnParam(S, 5) );
for( i = 0; i < (ACADO_NYN); ++i ) {
for( j = 0; j < ACADO_NYN; ++j ) {
acadoVariables.WN[i*ACADO_NYN+j] = SNmat[i*ACADO_NYN+j];
for( i = 0; i < (ACADO_NY); ++i ) {
for( j = 0; j < ACADO_NY; ++j ) {
acadoVariables.W[i*ACADO_NY+j] = Smat[i*ACADO_NY+j];
lbV = mxGetPr( ssGetSFcnParam(S, 5) );
ubV = mxGetPr( ssGetSFcnParam(S, 6) );
// lbAV = mxGetPr( ssGetSFcnParam(S, 8) );
// ubAV = mxGetPr( ssGetSFcnParam(S, 9) );
for( j=0; j < ACADO_NU; ++j ) acadoVariables.lbValues[i*ACADO_NU+j] = lbV[j];
for( j=0; j < ACADO_NU; ++j ) acadoVariables.ubValues[i*ACADO_NU+j] = ubV[j];
// for( j=0; j < ACADO_NU; ++j ) acadoVariables.lbAValues[i*ACADO_NU+j] = lbAV[j];
// for( j=0; j < ACADO_NU; ++j ) acadoVariables.ubAValues[i*ACADO_NU+j] = ubAV[j];
acado_initializeSolver();
// acado_preparationStep( );
static void mdlOutputs(SimStruct *S, int_T tid)
int i, j, iter, error;
double measurement[ACADO_NX];
acado_timer t;
double timeFdb, timePrep;
InputRealPtrsType in_x, in_ref, ol_Data, in_W, in_WN;
real_t *out_u0, *out_kktTol, *out_xTraj, *out_objVal;
in_x = ssGetInputPortRealSignalPtrs(S, 0);
ol_Data = ssGetInputPortRealSignalPtrs(S,2); // 实时数据
in_W = ssGetInputPortRealSignalPtrs(S, 3);
in_WN = ssGetInputPortRealSignalPtrs(S, 4);
for( i=0; i < ACADO_NX; ++i ) acadoVariables.x0[i] = (double)(*in_x[i]);
// for( i=0; i < ACADO_N; ++i ) {
// for( j=0; j < ACADO_NY; ++j ) acadoVariables.y[i*ACADO_NY+j] = (double)(*in_ref[j]);
for (i = 0; i < ACADO_N; ++i) {
for (j = 0; j < ACADO_NY; ++j) acadoVariables.y[i * ACADO_NY + j] = acadoVariables.y[ACADO_NY + i * ACADO_NY + j];
for ( i=0; i < ACADO_N; ++i ){
for ( j=0; j < ACADO_NOD; ++j ) acadoVariables.od[i*ACADO_NOD+j] = (double)(*ol_Data[j]);
for( i=0; i < ACADO_NYN; ++i ) acadoVariables.y[(ACADO_N-1)*ACADO_NY+i] = acadoVariables.yN[i];
// for( i=0; i < ACADO_NYN; ++i ) acadoVariables.yN[i] = (double)(*in_ref[i]);
for( i=0; i < ACADO_NY; ++i ) {
for( j=0; j < ACADO_NY; ++j ) acadoVariables.W[i*ACADO_NY+j] = (double)(*in_W[i*ACADO_NY+j]);
for( i=0; i < ACADO_NYN; ++i ) {
for( j=0; j < ACADO_NYN; ++j ) acadoVariables.WN[i*ACADO_NYN+j] = (double)(*in_WN[i*ACADO_NYN+j]);
// acado_set( “MAX_NUM_ITERATIONS”, 500 );
acado_tic( &t );
error = acado_feedbackStep( );
timeFdb = acado_toc( &t );
acado_tic( &t );
timePrep = acado_toc( &t );
printf("NMPC step (error value: %d):\n", error);
printf("Timing RTI iteration: %.3g ms + %.3g ms = %.3g ms \n", timeFdb*1e3, timePrep*1e3, (timeFdb+timePrep)*1e3);
printf("---------------------------------------------------------------\n");
/* return outputs and prepare next iteration */
out_u0 = ssGetOutputPortRealSignal(S, 0);
out_kktTol = ssGetOutputPortRealSignal(S, 1);
out_xTraj = ssGetOutputPortRealSignal(S, 2);
out_objVal = ssGetOutputPortRealSignal(S, 3);
for( i=0; i < ACADO_NU; ++i ) out_u0[i] = acadoVariables.u[i];
out_kktTol[0] = acado_getKKT( );
for( i = 0; i < ACADO_NX; ++i ) out_xTraj[i] = acadoVariables.x[i];
out_objVal[0] = acado_getObjective( );
static void mdlTerminate(SimStruct *S)
#ifdef MATLAB_MEX_FILE
#include “simulink.c”
#else
#include “cg_sfun.h”
#endif
again, I cannot help with ACADO.
However, Simulink examples based on code generation for acados can be found here: acados/examples/acados_matlab_octave/getting_started at master · acados/acados · GitHub
Dear Wenhui,
I see that you have faced errors in implementing ACADO into Simulink interface. I would like to ask for your help. Let me explain you my problem: I am developing an MPC controller for vehicle trajectory tracking. To achieve this, I use the bicycle model of the vehicle. When I include the longitudinal velocity Vx as a state variable (along with its time derivative), the optimization does not proceed, even if it is constant and properly initialized. On the other hand, if I remove Vx from the state vector and declare it separately as a variable, the optimization runs successfully. Additionally, I define the buses in Simulink and assign an initial value to enable the simulation. I am attaching the implementation code.
clc;
clear all;
close all;
clear mex;
% Controller settings
Ts = 0.01; % Sampling time
% Vehicle parameters of bicycle model (dynamic)
Vehicle_parameter;
%% ACADO set up
% Controller states
DifferentialState Vx doty dotpsi x y psi;
Control delta; % Definition of control variable
%OnlineData Vx; % Vx is now a parameter instead of a constant
%% Calculation of forces from the nonlinear tire model
s_f = 0.1;
s_r = 0.1;
Cf_non = par.Ccf;
Cr_non = par.Ccr;
Fxf = s_f * par.Csf;
Fxr = s_r * par.Csr;
% Now Vx will be passed from Simulink, we no longer define it here
%Vx = 10; % Constant velocity
f_ctrl = [
dot(Vx) == dotydotpsi;
dot(doty) == (Fxfsin(delta) + Cf_non*(delta-(doty + par.lfdotpsi)/(Vx))cos(delta))/par.m - (Cr_non(doty - par.lfdotpsi)/(Vx))/par.m - Vxdotpsi;…
dot(dotpsi) == (Fxfsin(delta) + Cf_non*(delta-(doty + par.lfdotpsi)/(Vx))cos(delta))par.lf/par.Iz + (Cr_non(doty - par.lfdotpsi)/(Vx))par.lr/par.Iz;…
dot(x) == Vxcos(psi) - dotysin(psi);…
dot(y) == Vxsin(psi) + dotycos(psi);…
dot(psi) == dotpsi];
%% ACADO: Controller formulation
acadoSet(‘problemname’, ‘PF_problem’);
Np = 20;
ocp = acado.OCP(0.0, Np*Ts, Np);
% Residual function definition based on ACADO
h = [diffStates ; controls];
hN = [diffStates]; % terminal
% Initialization weights
W = acado.BMatrix(eye(length(h)));
WN = acado.BMatrix(eye(length(hN)));
% Cost definition
ocp.minimizeLSQ(W, h);
ocp.minimizeLSQEndTerm(WN, hN); % terminal
% Constraints definition
beta_thd = 100 / 180 * pi; % absolute sideslip
delta_thd = 360 / 180 * pi / par.i_steer;
y_thd = 100;
psi_thd = 2*pi;
% Constraints in ACADO
ocp.subjectTo(-y_thd <= y <= y_thd);
ocp.subjectTo(-psi_thd <= psi <= psi_thd);
%ocp.subjectTo(-delta_thd <= delta <= delta_thd);
% Definition of ACADO prediction model
ocp.setModel(f_ctrl); % Set the model dynamics
% ACADO settings
mpc.set(‘HESSIAN_APPROXIMATION’, ‘GAUSS_NEWTON’);
mpc.set(‘DISCRETIZATION_TYPE’, ‘MULTIPLE_SHOOTING’);
mpc.set(‘INTEGRATOR_TYPE’, ‘INT_IRK_GL2’);
mpc.set(‘NUM_INTEGRATOR_STEPS’, 3 * Np);
mpc.set(‘LEVENBERG_MARQUARDT’, 1e-4);
mpc.set(‘SPARSE_QP_SOLUTION’, ‘FULL_CONDENSING_N2’);
mpc.set(‘QP_SOLVER’, ‘QP_QPOASES3’);
mpc.set(‘MAX_NUM_QP_ITERATIONS’, 200);
mpc.set(‘HOTSTART_QP’, ‘YES’);
mpc.set(‘GENERATE_SIMULINK_INTERFACE’, ‘YES’); % Interface with Simulink
%% Export and Compile flags
EXPORT = 1;
COMPILE = 1;
% Export code to the defined folder
if EXPORT
mpc.exportCode(‘export_MPC’);
% Compilation of the S-function using autogenerated make script
if COMPILE
global ACADO_;
copyfile([ACADO_.pwd ‘/…/…/external_packages/qpoases3’], ‘export_MPC/qpoases3’)
cd export_MPC
make_acado_solver_sfunction
copyfile(‘acado_solver_sfun.mex*’, ‘…/’)
cd …
%% Initial MPC settings
disp(‘Initialization’)
Vini = 10;
X0 = [Vini 0 0 0 0 0]; % Initial states conditions
% Initialize controller bus
input.x = repmat(X0, Np + 1, 1).‘; % Size Np + 1
%input.od = zeros(Np+1,1); % Size Np + 1
input.od = repmat(Vini, Np + 1, 1)’;
Uref = zeros(Np, 1);
input.u = Uref.‘; % Control inputs
input.y = [repmat(X0, Np, 1) Uref].’; % Reference trajectory
input.yN = X0.‘; % Terminal reference
input.W = diag([0 0 0 0 0 5 1]); % Weight tuning
input.WN = diag([0 0 0 0 5 1]); % Terminal weight tuning
input.x0 = X0.’; % Initial state
%input.od = ones(1,Np + 1) * Vx_ini; % Online data (Vx as an external parameter)
% Inicializar la estructura ‘init’ que pasará datos al bloque de Simulink
init.x = input.x(:).‘;
init.u = input.u(:).’;
init.y = input.y(:).‘;
init.yN = input.yN(:).’;
init.W = input.W(:).‘;
init.WN = input.WN(:).’;
init.x0 = input.x0(:).‘;
%init.od = input.od(:).’; % Asegurar que se inicializa la entrada od (Vx)
Now, I use ACADOS solvers to optimal my problem. I’m very sorry!
