Mario
December 10, 2025, 7:32pm
1
Hi guys,
I am using acados in Python anb I would like to exploit structure in my model with implicit integrators. In particular, I have quite some states that are simple integrators of the control inputs. If I got that right, I could use GNSF to exploit this structure, but I was unable to find an example that guides me. My issue is also that I need to use MX as I have splines in my model.
If I got that right I should use something like
acados_ocp.solver_options.integrator_type = 'GNSF'
# acados_ocp.solver_options.collocation_type = "GAUSS_RADAU_IIA"
acados_ocp.solver_options.collocation_type = "GAUSS_LEGENDRE"
acados_ocp.solver_options.sim_method_num_stages = 2
acados_ocp.solver_options.sim_method_num_steps = 1
acados_ocp.solver_options.sim_method_newton_iter = 5
acados_ocp.solver_options.sim_method_jac_reuse = True
but then I get a message that automatic detection is not supported for MX, so I suppose I have to pass it myself. My question is how can I do that.
Many thanks in advance!
Ciao,
Mario
FreyJo
December 13, 2025, 10:01am
2
Ciao Mario,
Indeed the structure detection does not work with MX.
Symbolic manipulations with MX are very limited in CasADi.
We worked on a clear interface for manual definition of a GNSF model, see acados PR 1725 .
In particular, this example shows how to define a model with GNSF structure manually: acados/examples/acados_python/pendulum_on_cart/sim/extensive_example_sim.py at main · acados/acados · GitHub
I hope this enables you to use GNSF-IRK successfully
I think for MX, there could be a workflow to perform preliminary structure detection without the spline and use ca.substitute.
Mario
December 19, 2025, 3:56pm
3
Thanks Jonathan,
that was very helpful!
Now the code starts compiling, but at some point I get the following error
cc -shared boat_dae_constraints/boat_dae_constr_h_fun_jac_uxt_zt.o boat_dae_constraints/boat_dae_constr_h_fun.o boat_dae_cost/boat_dae_cost_y_0_fun.o boat_dae_cost/boat_dae_cost_y_0_fun_jac_ut_xt.o boat_dae_cost/boat_dae_cost_y_0_hess.o boat_dae_cost/boat_dae_cost_y_fun.o boat_dae_cost/boat_dae_cost_y_fun_jac_ut_xt.o boat_dae_cost/boat_dae_cost_y_hess.o boat_dae_cost/boat_dae_cost_y_e_fun.o boat_dae_cost/boat_dae_cost_y_e_fun_jac_ut_xt.o boat_dae_cost/boat_dae_cost_y_e_hess.o acados_solver_boat_dae.o boat_dae_model/boat_dae_gnsf_phi_fun.o boat_dae_model/boat_dae_gnsf_phi_fun_jac_y.o boat_dae_model/boat_dae_gnsf_phi_jac_y_uhat.o boat_dae_model/boat_dae_gnsf_f_lo_fun_jac_x1k1uz.o boat_dae_model/boat_dae_gnsf_get_matrices_fun.o -o libacados_ocp_solver_boat_dae.dylib -L/Users/zmario/src/acados/lib -lacados -lhpipm -lblasfeo -lm \
-L -l
ld: warning: search path '-l' not found
acados was compiled with OpenMP.
error: ocp_nlp_opts_set: wrong field: anderson_activation_threshold
I am a bit surprised, because I don’t know even what that is…
My options are
# set prediction horizon
acados_ocp.solver_options.N_horizon = N
acados_ocp.solver_options.tf = T
acados_ocp.solver_options.qp_solver = 'PARTIAL_CONDENSING_HPIPM'
acados_ocp.solver_options.hessian_approx = 'GAUSS_NEWTON'
FreyJo
December 19, 2025, 4:55pm
4
Hi Mario,
You need to recompile acados after pulling a new version.
I think you have some old binaries around that cause the error.
Can you double check this?
I think the warning can be ignored.
Mario
December 20, 2025, 12:44pm
5
Right, I got distracted on that… good catch, thank you!
