Hello, Acados Team,
I encountered an issue: after setting the h function, I am unable to change my initial position x0. Even when I use:
solver.constraints_set(0, 'ubx', initial_state)
solver.constraints_set(0, 'lbx', initial_state)
It does not modify the initial x0 that was initially set in the OCP.
Below is my code:
N = 20
dt = 0.1
nx_current = 7 # x, y, vx, vy, ax, ay, yaw
nx_pre = 3 # x_pre, y_pre, yaw_pre
nx = nx_current + nx_pre # 10
nu = 3 # jerk_x, jerk_y, w
ny = nx_current + nu # :x, y, vx, vy, ax, ay, yaw, jerk_x, jerk_y, w
ny_e = nx_current
nh = 6
def define_track_model():
x = SX.sym('x')
y = SX.sym('y')
vx = SX.sym('vx')
vy = SX.sym('vy')
ax = SX.sym('ax')
ay = SX.sym('ay')
yaw = SX.sym('yaw')
x_pre = SX.sym('x_pre')
y_pre = SX.sym('y_pre')
yaw_pre = SX.sym('yaw_pre')
jerk_x = SX.sym('jerk_x') #
jerk_y = SX.sym('jerk_y') #
w = SX.sym('w') #
x_aug = vertcat(x, y, vx, vy, ax, ay, yaw, x_pre, y_pre, yaw_pre)
x_next = x + vx * dt + 0.5 * ax * dt**2
y_next = y + vy * dt + 0.5 * ay * dt**2
vx_next = vx + ax * dt
vy_next = vy + ay * dt
ax_next = ax + jerk_x * dt
ay_next = ay + jerk_y * dt
yaw_next = yaw + w * dt
f_discrete = vertcat(
x_next,
y_next,
vx_next,
vy_next,
ax_next,
ay_next,
yaw_next,
x,
y,
yaw
model.name = 'augmented_yaw_model'
model.x = x_aug #
model.u = vertcat(jerk_x, jerk_y, w)
model.disc_dyn_expr = f_discrete
d_min = SX.sym('d_min')
dx = SX.sqrt((x - x_pre)**2 + (y - y_pre)**2)
con_h_expr = vertcat(
d_min - dx
model.con_h_expr = con_h_expr
model.con_h_expr_e = con_h_expr
model.p = vertcat(d_min)
return model
def solver_model():
model = define_track_model()
T_f = N * dt
ocp.solver_options.N_horizon = N
ocp.solver_options.tf = T_f
ocp.solver_options.integrator_type = 'DISCRETE' #
'''cost function'''
# cost function
''' Vx Vu'''
Vx = np.zeros((ny, nx))
for i in range(nx_current) :
Vx[i, i] = 1
ocp.cost.Vx = Vx #
# Vx_e = np.zeros((nx_current, nx_current))
Vx_e = np.zeros((nx_current, nx))
for i in range(nx_current):
Vx_e[i, i] = 1
ocp.cost.Vx_e = Vx_e
Vu = np.zeros((ny, nu))
for i in range(nu) :
Vu[i, i] = 1
ocp.cost.Vu = Vu
''' Q R W '''
Q = 1e2 * np.eye(nx_current)
Q[0, 0] = 1e3 # x
Q[1, 1] = 1e3 # y
Q[2, 2] = 1e1 # vx
Q[3, 3] = 1e1 # vy
Q[4, 4] = 1e1 # ax
Q[5, 5] = 1e1 # ay
Q[6, 6] = 1e1 # yaw
R = 1e1 * np.eye(nu)
R[2, 2] = 1e0
W = np.block([
[Q, np.zeros((nx_current, nu))],
[np.zeros((nu, nx_current)), R]
ocp.cost.W = W
ocp.cost.W_e = Q
ocp.cost.yref = np.zeros((nx_current + nu,)) # [x_ref, y_ref, vx_ref, vy_ref, ax_ref, ay_ref, yaw_ref, u_ref_x, u_ref_y]
ocp.cost.yref_e = np.zeros((nx_current,))
'''constraints'''
x0 = np.zeros((nx,))
ocp.constraints.x0 = x0
jerk_max = 5.0
w_max = 5
ocp.constraints.lbu = np.array([-jerk_max, -jerk_max, -w_max])
ocp.constraints.ubu = np.array([jerk_max, jerk_max, w_max])
default_p = np.array([1.0])
ocp.parameter_values = default_p
nh = 1
ocp.constraints.lh = np.zeros(nh)
ocp.constraints.uh = 1e9 * np.ones(nh)
ocp.constraints.lh_e = np.zeros(nh)
ocp.constraints.uh_e = 1e9 * np.ones(nh)
solver = AcadosOcpSolver(ocp, json_file='acados_ocp.json')
return solver
if __name__ == "__main__":
initial_state = np.zeros((nx,))
initial_state[0] = 10.0
initial_state[1] = 0.0
initial_state[2] = 0.0
initial_state[3] = np.pi
initial_state[4] = -np.pi**2 / 10.0
initial_state[5] = 0.0
initial_state[6] = np.pi / 2
initial_state[7] = 10.0
initial_state[8] = 0.0
initial_state[9] = np.pi / 2
solver = solver_model()
ref_traj = define_ref_traj(N, dt=dt)
for i in range(N) :
yref = np.hstack((ref_traj[i], np.zeros(nu)))
solver.cost_set(i, 'yref', yref)
solver.cost_set(N, 'yref', ref_traj[-1])
status = solver.solve()
# solver.
if status != 0:
print("false", status)
else:
print("true", status)
solver.print_statistics()
last_x = []
for i in range(N+1):
xi = solver.get(i, 'x')
last_x.append(xi)
last_x = np.array(last_x)
last_u = []
for i in range(N):
ui = solver.get(i, 'u')
last_u.append(ui)
last_u = np.array(last_u)
x_traj = last_x[:, 0]
y_traj = last_x[:, 1]
yaw_traj = last_x[:, 6]
plot_traj_all([x_traj, y_traj, yaw_traj], ref_traj, alpha_value=0.4, FOV_length_value=5.0, N=N)
