TypeError: 'ABCMeta' object is not subscriptable
-What interface of acados are you using? Python 3.8.10
The machine is ubuntu 20.04
I installed acados as recommended in the documentation:
git clone https://github.com/acados/acados.git
cd acados
git submodule update --recursive --init
mkdir -p build
cd build
cmake-gui
make
pip install -e <acados_root>/interfaces/acados_template
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:"<acados_root>/lib"
export ACADOS_SOURCE_DIR="<acados_root>"
(Also i did replace acados root with my actual acados root)
Then i tried import acados_template and i got the following error:
Python 3.8.10 (default, Sep 11 2024, 16:02:53)
[GCC 9.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
File “”, line 1, in
File “/home/nouf/acados/interfaces/acados_template/acados_template/init.py”, line 39, in
from .acados_ocp_batch_solver import AcadosOcpBatchSolver
File “/home/nouf/acados/interfaces/acados_template/acados_template/acados_ocp_batch_solver.py”, line 32, in
from .acados_ocp_solver import AcadosOcpSolver
File “/home/nouf/acados/interfaces/acados_template/acados_template/acados_ocp_solver.py”, line 62, in
class AcadosOcpSolver:
File “/home/nouf/acados/interfaces/acados_template/acados_template/acados_ocp_solver.py”, line 715, in AcadosOcpSolver
seed_x: Optional[Sequence[Tuple[int, np.ndarray]]],
TypeError: ‘ABCMeta’ object is not subscriptable
Can anyone please help me with this error, has anyone met this error before?
thanks for reporting, seems to be an issue of importing the Sequence type. I just pushed a fix, please try again with the current master. :slight_smile:
That worked, Thank you!
