Solver runs slower in NVIDIA Jetson TX2 platform?
I am using python to generate C code for an MPC controller and then use that C code in a C++ environment. Everything works as expected with my MPC and on the desktop computer, I get less than 1ms solve times, which is awesome. However, when I run the same code in an NVIDIA Jetson TX2 platform, I get solve times that are 5x-8x times larger. Is this normal? Is there anything to be done to improve the solve times in arm-based platforms?
Right now I compile acados in the Jetson and I generate the code in the Jetson (kudos to this topic, was necessary: Problems with t_renderer).
These are the options I use:
    ocp.solver_options.qp_solver = "PARTIAL_CONDENSING_HPIPM"  # "PARTIAL_CONDENSING_HPIPM", "FULL_CONDENSING_HPIPM"
    ocp.solver_options.nlp_solver_type = "SQP_RTI"     # "SQP", "SQP_RTI"
    ocp.solver_options.hessian_approx = "GAUSS_NEWTON"  # "GAUSS_NEWTON", "EXACT"
    ocp.solver_options.integrator_type = "ERK"   # "ERK", "IRK", "GNSF"
Maybe any tips to get it to run faster?
Thanks a lot!
Angel.
I guess it is to be expected that the solver is slower on the platform.
Did you compile BLASFEO with the dedicated target?
I guess, you should go for ARMV8A_ARM_CORTEX_A57.
Thanks a lot for this suggestion, I get an improvement of around 15-20% in solve times with this :slight_smile:
Another thing I’ll try is to pose my problem as a NONLINEAR_LS (would need to do this trick then: Gradient term in Linear LS cost function - #6 by jdeschut) instead of EXTERNAL cost module and see if there is any performance improvement.
Thanks a lot!
Did you get any performance improvement after implementing
the trick?
Yes, I got another ~20% performance improvement!
