Running slightly different models for integrator vs solver
Hi
I’m trying to examine the effect of model inaccuracies on the solver so I want to load a model with different parameters in the AcadosSimSolver and then use it against the acados solver.
I am new to acados but am following the getting_started/minimal_example_closed_loop.py
I’ve tried establishing two separate ocp but it seems the sim is still using the AcadosOcpSolver model parameters: Note that I’ve broken out the setup of an ocp type into its own function as both solvers need to be setup identically, I’m only changing one of the parameters M.
def setOCP(ocp, x0, N_horizon=20, Tf=2., uMax=0.2, TMax=20.):
    nx = ocp.model.x.size()[0]
    nu = ocp.model.u.size()[0]
    print(f'nu: {nu:d}')
    ny = nx + nu
    ny_e = nx
    ocp.dims.N = N_horizon
    Q_mat = 4.*np.diag(np.ones((nx)))
    Q_mat[0, 0] = 5.
    Q_mat[1, 1] = 5.
    Q_mat[2, 2] = 5.
    R_mat = 2e-2*np.diag(np.ones((nu)))
    ocp.cost.W = scipy.linalg.block_diag(Q_mat, R_mat)
    ocp.cost.W_e = Q_mat
    ocp.model.cost_y_expr = vertcat(ocp.model.x, ocp.model.u)
    ocp.model.cost_y_expr_e = ocp.model.x
    ocp.cost.yref = np.zeros((ny, ))
    ocp.cost.yref_e = np.zeros((ny_e, ))
    #control constraints
    ocp.constraints.lbu = np.array([-uMax, -uMax, -uMax, 0.])
    ocp.constraints.ubu = np.array([uMax, uMax, uMax, TMax])
    ocp.constraints.idxbu = np.array([0,1,2,3])
    ocp.constraints.x0 = x0
    ocp.solver_options.sim_method_newton_iter = 10
    ocp.solver_options.qp_solver_iter_max=600
    ocp.solver_options.qp_solver_cond_N = N_horizon
    ocp.solver_options.tf = Tf
    return ocp
def setup(x0, N_horizon=20, Tf=2., uMax=0.2, TMax=20.):
    model = export_model_control()
    ocp = setOCP(ocp, x0, N_horizon, Tf, uMax, TMax )
    M=1.5
    ocp.parameter_values=np.array([M])
    ocp_dist = AcadosOcp()
    model2 = export_model_control()
    ocp_dist.model = model2
    ocp_dist = setOCP(ocp_dist, x0, N_horizon, Tf, uMax, TMax)
    M2=20.5
    ocp_dist.parameter_values=np.array([M2])
    solver_json = 'acados_ocp_' + model.name + '.json'
    solver_dist_json = 'acados_ocp_' + model.name + '_dist.json'
    acados_ocp_solver = AcadosOcpSolver(ocp, json_file = solver_json)
    acados_integrator = AcadosSimSolver(ocp_dist, json_file = solver_dist_json)
    return acados_ocp_solver, acados_integrator
To be clear, adjusting the value of M2 makes no difference to the sim model’s behaviour, why is this and how do the json files work?
many thanks for some insight.
I created a minimal functional example. This time the model is a spring mass damper system. The current way this is set up is that the OcpSolver model has no damping, and no control effort (Fmax is 0) but the ocp_sim model has a model that has some damping.
When I simulate it I only see the output as per the undamped version not the damped version which should be what is simulated.
This is example is all that you need to run and view the issue. Hope it helps!
from acados_template import AcadosModel, AcadosOcp, AcadosOcpSolver, AcadosSimSolver
from casadi import SX, vertcat
import scipy.linalg
def export_spring_mass_damper_model() -> AcadosModel:
    model_name='spring_mass_damper'
    g=9.81
    #Parameters
    M = SX.sym('M') #Mass
    D = SX.sym('D') #damping constant
    K = SX.sym('K') #spring constant
    mu= SX.sym('mu') #Coefficient of Friction
    p = vertcat(M, D, K, mu) #Parameter Vector
    x = SX.sym('x') #mass position
    v = SX.sym('v') #mass velocity
    x_state = vertcat(x, v)
    xdot = SX.sym('xdot')
    vdot = SX.sym('vdot')
    xdot_state =vertcat(xdot, vdot)
    #Controls
    F = SX.sym('F')
    u = vertcat(F)
    #Dynamics
    f_explicit = vertcat(
            v,
            (F-D*v -K*x)/M
    f_implicit = xdot_state - f_explicit
    model.f_expl_expr = f_explicit
    model.f_impl_expr = f_implicit
    model.x = x_state
    model.xdot = xdot_state
    model.u = u
    model.p = p
    model.name=model_name
    return model
def setOCP(ocp, x0, N_horizon=None, Tf=None, FMax=None):
    ny = nx + nu
    ny_e = nx
    Q_mat = 2.*np.diag(np.ones((nx)))
    ocp.constraints.lbu = np.array([-FMax])
    ocp.constraints.ubu = np.array([FMax])
    ocp.solver_options.qp_solver_iter_max=50
    return ocp
def setup(x0, N_horizon, Tf, FMax):
    model = export_spring_mass_damper_model()
    ocp.model=model
    ocp = setOCP(ocp, x0, N_horizon, Tf, FMax)
    M=1.0
    D=0.0
    K=0.5
    mu=0.01 #Coefficient of Friction
    ocp.parameter_values = np.array([M,D, K, mu])
    ocp_sim=AcadosOcp()
    model_sim = export_spring_mass_damper_model()
    ocp_sim.model=model_sim
    ocp_sim = setOCP(ocp_sim, x0, N_horizon, Tf, FMax)
    mu_sim = 0.01
    ocp_sim.parameter_values = np.array([M,D+0.1, K, mu_sim])
    acados_ocp_solver = AcadosOcpSolver(ocp)
    acados_integrator = AcadosSimSolver(ocp_sim)
def main():
    FMax=0.0
    ubu=np.array([FMax])
    x0=np.array([0.3, 0.0])
    Tf=2.0
    N_Horizon=20
    ocp_solver, integrator = setup(x0, N_Horizon, Tf, FMax)
    nx = ocp_solver.acados_ocp.dims.nx
    nu = ocp_solver.acados_ocp.dims.nu
    Nsim=300
    simX = np.ndarray((Nsim+1, nx))
    simU = np.ndarray((Nsim, nu))
    simRef = np.ndarray((Nsim, nx+nu))
    simX[0, :] =x0
    t = np.zeros((Nsim))
    #do som initial iterations to start with a good guess
    num_iter_initial=5
    for _ in range(num_iter_initial):
        ocp_solver.solve_for_x0(x0_bar = x0)
    time=0.
    for i in range(Nsim):
        time =i*(Tf/N_Horizon)
        #Get and Set Reference
        yref=genCircularTrajectory(time, N=N_Horizon, tF=Tf)
        for j in range(N_Horizon):
            ocp_solver.set(j, "yref", yref[j,:])
        yref_e = yref[N_Horizon, :-4]
        ocp_solver.set(N_Horizon, "yref", yref_e)
        simRef[i, :] =0
        #Solve Control Solution
        simU[i, :] = ocp_solver.solve_for_x0(x0_bar = simX[i, :])
        t[i] = ocp_solver.get_stats('time_tot')
        simX[i+1, :] = integrator.simulate(x=simX[i, :], u=simU[i,:])
    t*= 1000
    print(f'Computation time in ms: min {np.min(t):.3f} median {np.median(t):.3f} max {np.max(t):.3f}')
    plot_system(np.linspace(0, (Tf/N_Horizon)*Nsim, Nsim+1),ubu , simX, simU, simRef)
def plot_system(shooting_nodes, u_max, X_true, U=None, Y=None, X_est=None, Y_measured=None, latexify=False, plt_show=True, X_true_label=None):
    Params:
        shooting_nodes: time values of the discretization
        u_max: maximum absolute value of u
        U: arrray with shape (N_sim-1, nu) or (N_sim, nu)
        X_true: arrray with shape (N_sim, nx)
        X_est: arrray with shape (N_sim-N_mhe, nx)
        Y_measured: array with shape (N_sim, ny)
        latexify: latex style plots
    if latexify:
        latexify_plot()
    WITH_ESTIMATION = X_est is not None and Y_measured is not None
    N_sim = X_true.shape[0]
    nx = X_true.shape[1]
    Tf = shooting_nodes[N_sim-1]
    t = shooting_nodes
    Ts = t[1] - t[0]
    if WITH_ESTIMATION:
        N_mhe = N_sim - X_est.shape[0]
        t_mhe = np.linspace(N_mhe * Ts, Tf, N_sim-N_mhe)
    if U is not None:
        nu = U.shape[1]
        input_labels=['$F$']
        for i in range(nu):
            plt.subplot(nu+nx+1, 1, i+1)
            line, = plt.step(t[:-1], U[:,i])
            line.set_color('r')
            plt.ylabel(input_labels[i])
            plt.xlabel('$t$')
            plt.hlines(u_max[i], t[0], t[-1], linestyles='dashed', alpha=0.7)
            plt.hlines(-u_max[i], t[0], t[-1], linestyles='dashed', alpha=0.7)
            plt.ylim([-1.2*u_max[i], 1.2*u_max[i]])
            plt.xlim(t[0], t[-1])
            plt.grid()
    states_lables = ['$x$', '$v$']
    assert(len(states_lables) == nx)
    for i in range(nx):
        if U is not None:
            plt.subplot(nx+nu+1, 1, nu+i+1)
        else:
            plt.subplot(nx+1, 1, i+1)
        line, = plt.plot(t, X_true[:, i], label='true')
        if X_true_label is not None:
            line.set_label(X_true_label)
        plt.plot(t[1:], Y[:, i], 'g', label='ref')
        if WITH_ESTIMATION:
            plt.plot(t_mhe, X_est[:, i], '--', label='estimated')
            plt.plot(t, Y_measured[:, i], 'x', label='measured')
        plt.ylabel(states_lables[i])
        plt.xlabel('$t$')
        plt.grid()
        plt.legend(loc=1)
    plt.subplots_adjust(left=None, bottom=None, right=None, top=None, hspace=0.4)
    if plt_show:
        plt.show()
if __name__ == "__main__":
    main()
normally, you should create an integrator (AcadosSimSolver) using an AcadosSim object.
Creating one from an AcadosOcp object only works if you have created an AcadosOcpSolver before with the exact same AcadosOcp description.
Unfortunately, it is a bit hard to create a check for this inside the creation of AcadosSimSolver.
Creating an AcadosSimSolver from AcadosOcp is just a convenience thing to get an integrator that exactly replicates the dynamics in an OCP solver.
Hi @FreyJo, that has made a difference. They seem to be two different systems now.
