QP solver returned error status 3 in SQP iteration 2, QP iteration 4. again and again, anyone can help me!
i occur this problem as follow:
[MPC_SLOVER]
MPC Executing time: 0.003225s
MPC status: 0
State_x = 4.000000	 State_y = 1.000000	 State_angle = 1.570796
Refernce_x = 4.500000	 Refernce_y = 2.000000	 Refernce_angle = 0.000000
Short_x = 4.500000	 Short_y = 1.000000	 Short_angle = 0.000000
Linear_X = 0.306735	 Angular_Z = -0.500000
Distance to short = 0.500000
Distance to target = 1.118034
Theta difference = 1.570796
**QP solver returned error status 3 in SQP iteration 2, QP iteration 4.**
Error status: 4
[MPC_SLOVER]
MPC Executing time: 0.001433s
MPC status: 4
State_x = 4.064686	 State_y = 1.271739	 State_angle = 1.111437
Refernce_x = 4.500000	 Refernce_y = 2.250000	 Refernce_angle = 0.000000
Short_x = 4.500000	 Short_y = 1.250000	 Short_angle = 0.000000
Linear_X = 0.000000	 Angular_Z = 0.000000
Distance to short = 0.435856
Distance to target = 1.070744
Theta difference = 1.111437
and this my ocp.py
#!/usr/bin/env python3
from model import export_spot_model
from casadi import *
from acados_template import AcadosOcp, AcadosOcpSolver, ocp_get_default_cmake_builder
import scipy.linalg
import math
def gen_model(prediction_steps=10, horizon_duration=1,
                max_v=0.6, min_v=-0.6,
                max_w=0.5,  min_w=-0.5,
                angle_threshold=0.05, distance_threshold=0.03):
    model = export_spot_model(horizon_duration/prediction_steps)
    ocp.dims.N = prediction_steps
    ocp.solver_options.tf = horizon_duration
    # 狀態變數
    robot_x = ocp.model.x[0]
    robot_y = ocp.model.x[1]
    robot_th = ocp.model.x[2]
    # 目標點變數
    ref_x = ocp.model.p[0]
    ref_y = ocp.model.p[1]
    ref_th = ocp.model.p[2]
    # 直線方程參數
    shortest_x = ocp.model.p[3]
    shortest_y = ocp.model.p[4]
    shortest_th = ocp.model.p[5]
    # 計算與目標點的誤差
    error_x = ref_x - robot_x
    error_y = ref_y - robot_y
    error_th = ref_th - robot_th
    # 修正角度誤差到 [-pi, pi] 範圍內
    # error_th = atan2(sin(error_th), cos(error_th))
    # error_th = pi * ((sin(error_th))**2)  # 這是你提到的部分的修正
    error_th = math.pi * ((1 - cos(error_th))/2)
    # 將誤差整合到一個向量中
    error = vertcat(error_x, error_y, error_th)
    Q = np.array([[0.5, 0.0, 0.0], [0.0, 1.0, 0.0], [0.0, 0.0, 1.0]]) # State weight
    J_error = error.T@Q@error
    R = np.array([[0.5, 0.0], [0.0, 0.5]]) # Control weight
    J_control = ocp.model.u.T@R@ocp.model.u
    # W = scipy.linalg.block_diag(Q, R)
    J_cost = (J_error + J_control)/2
    J_cost_e = (J_error)/2
    ocp.model.cost_expr_ext_cost = J_cost
    ocp.model.cost_expr_ext_cost_e = J_cost_e
    # set constraints
    ocp.constraints.lbu = np.array([min_v, min_w])
    ocp.constraints.ubu = np.array([max_v, max_w])
    # ocp.constraints.constr_exp_h = model.con_h_expr
    # ocp.constraints.lh = np.array([0.0])
    # ocp.constraints.uh = np.array([999.0])
    # ocp.constraints.lh_e = np.array([0.0])
    # ocp.constraints.uh_e = np.array([999.0])
    # ocp.constraints.uphi = np.array([999])
    # ocp.constraints.lphi = np.array([0.0])
    ocp.constraints.x0 = np.array([0, 0, 0]) # must set so you can set initial state
    ocp.parameter_values = np.array([0, 0, 0, 0, 0, 0])
    # solver options
    ocp.solver_options.qp_solver = 'FULL_CONDENSING_HPIPM'
    ocp.solver_options.hessian_approx = 'EXACT'
    ocp.solver_options.integrator_type = 'DISCRETE'
    ocp.solver_options.print_level = 0
    ocp.solver_options.nlp_solver_max_iter = 100
    # ocp.solver_options.globalization = 'MERIT_BACKTRACKING'
    # ocp_get_default_cmake_builder()
    AcadosOcpSolver(ocp, json_file = ocp.model.name + '_acados_ocp.json')
if __name__ == '__main__':
    gen_model()
anyone can help me ?
There were many posts about these status, you should take a look at the others.
For me, you should check your weight cost matrix. A negative element in your matrix will cause problem unsolved.
Excuse me, may I ask which negative element you are referring to state, control , parameter or cost function matrix value? i had see many posts about these status, but i didn’t see any detailed solution.
