Python persists asking for properties for initial shooting node
I am trying to formulate an mpc problem in python and I am using:
When i am trying to run it, it looks for W_0 and yref_0 and throws an exception for inconsistent dimensions.
Since I am not defining cost_type_0 why does it complain?
If you do not specify the cost at the initial shooting node, acados will copy whatever is defined as a path cost for the initial node.
Thus, if you get an exception about inconsistent dimension you should check your path cost.
