It’s Ubuntu 16.04, Python 3.5, pip20.3.4
I want to run acados by testing the example code.
Code
python3 minimal_example_closed_loop.py
this error message
File "minimal_example_closed_loop.py", line 37, in <module>
from acados_template import AcadosOcp, AcadosOcpSolver, AcadosSimSolver
File "/home/ruoyo16/.local/lib/python3.5/site-packages/acados_template/__init__.py", line 35, in <module>
from .generate_c_code_explicit_ode import *
File "/home/ruoyo16/.local/lib/python3.5/site-packages/acados_template/generate_c_code_explicit_ode.py", line 36, in <module>
from .utils import ALLOWED_CASADI_VERSIONS, is_empty, casadi_version_warning
File "/home/ruoyo16/.local/lib/python3.5/site-packages/acados_template/utils.py", line 215
os_cmd = f"{tera_path} '{template_glob}' '{in_file}' '{json_path}' '{out_file}'"
SyntaxError: invalid syntax
Any other code "from acados_template import (AcadosModel, AcadosOcp, AcadosOcpSolver" occurs the same problem
