Interface:
-) Matlab
-) Windows
I compiled acados with OSQP and QPOASES. However, everytime when I try to run the minimal_example_ocp.m, the compilation fails mostly with similar errors depending if I compile only with OSQP or both. I tried with external solvers off and it does work.
Here is one of the errors:
C:/Users/phman/repos/Z_acados/interfaces/acados_matlab_octave/../../lib/qpOASES_e.lib(MessageHandling.c.obj):MessageHandling.c:(.text+0x93):
undefined reference to `__imp___acrt_iob_func'
CMakeFiles\acados_ocp_solver_pendulum.dir\build.make:109: recipe for target 'acados_ocp_solver_pendulum.dll'
failed
Additionally, I think I found a bug in the auto generated CMakeFile:
Got status 1, result: CMake Error at CMakeLists.txt:70 (set):
Syntax error in cmake code at
C:/Users/phman/repos/Z_acados/examples/acados_matlab_octave/getting_started/c_generated_code/CMakeLists.txt:71
when parsing string
pendulum_model\pendulum_expl_ode_fun.c
Invalid character escape '\p'.
It is due to the backslash in the CMakeLists file.
An easy fix which I have done, is to modify the GenerateContext() on line 154 to not use out{end+1} = fullfile(rel_fun_dir, [fun_name, '.c']); but rather replace it with out{end+1} = [rel_fun_dir,'/', fun_name, '.c']
Help would be appreciated with the other QP Solvers!
Best wishes!
