Problem of installing Python Interface
I have a problem when installing python interface.
I install the acados and python interface following the instructions.
But when i attempt to that if everything works. I get started with the example <acados_root>/examples/acados_python/getting_started/ocp/minimal_example_ocp.py . But it falied . The result is as below.
are you on some non-standard architecture?
Can you try to compile tera renderer natively instead of using the binary?
See Problems with t_renderer
