Ny for external cost function
Hi, I am using an external cost function, since it doesn’t fit into the standard linear least squares form. While setting up my problem, I noticed that ny is mandatory. How do I find the ny for an external cost function?
Hi Christian,
first of all, welcome to the Forum :wave:
Indeed, it should not be mandatory to set those dimensions, since it is not used in case of an external cost funciton. I just changed this here:
https://github.com/FreyJo/acados/pull/27/commits/24382c7d69ab8f4a20f00bc4e06d3c96d6cb60e2
You can just set them to 0, if you dont want to switch acados version.
Hi FreyJo,
Thank you for your quick response. That makes sense.
