Min Step error in Python WIndows
Hi, since around 2 months I’ve been receiving a MINSTEP error from the QP solver. This is my current code. I’m trying to implement a swingup and stabilization of an inverted pendulum. I’ve pretty much tried everything I could imagine. Does anyone have an idea? Could it be my solver options or my model itself?
Kind regards
import casadi as ca
import matplotlib.patches as mpatches
from matplotlib.animation import FuncAnimation
import time
import pyads
import control
from scipy.signal import cont2discrete
from datetime import datetime
import control
import time
import os
import shutil
from ekf_observer import EKF
import sys
# DLL VERWALTUNG
ACADOS_LIB_DIR = r"C:\Users\mz\Desktop\acados\lib"
C_GEN_DIR      = "c_generated_code"
REQUIRED_DLLS  = ["acados.dll", "blasfeo.dll", "hpipm.dll", "qpOASES_e.dll"]
def clean_and_prepare_generated_code():
    if not os.path.exists(C_GEN_DIR):
        os.makedirs(C_GEN_DIR)
    else:
        for item in os.listdir(C_GEN_DIR):
            item_path = os.path.join(C_GEN_DIR, item)
            # Alles löschen außer den 4 benötigten DLLs
            if os.path.isfile(item_path) and item not in REQUIRED_DLLS:
                os.remove(item_path)
            elif os.path.isdir(item_path):
                shutil.rmtree(item_path)
    # Fehlende DLLs kopieren
    for dll in REQUIRED_DLLS:
        dst = os.path.join(C_GEN_DIR, dll)
        if not os.path.exists(dst):
            shutil.copy(os.path.join(ACADOS_LIB_DIR, dll), dst)
            print(f"Kopiert: {dll}")
# ---------------- ADS / Timing ----------------
AMS_NET_ID = "134.28.49.25.1.1"  # deine AMS-NetID
PLC_IP     = "134.28.49.25"      # IP der Steuerung
AMS_PORT   = 851                 # Standard-Port für PLC1
# ---------------- Encoder ----------------
ENCODER_CPR_ARM = 8192  # Counts per Revolution
ENCODER_CPR_PENDLE = 4096  # Counts per Revolution
UINT16_MAX = 65536  # 2^16 für UINT16 wrap-around
# Hilfsfunktionen:
def handle_encoder_overflow(current, previous, max_value=65536):
    diff = current - previous
    # Überlauf nach oben (0 -> 65535)
    if diff < -max_value / 2:
        diff += max_value
    # Überlauf nach unten (65535 -> 0)
    elif diff > max_value / 2:
        diff -= max_value
    return diff
def counts_to_rad_delta(diff_counts, cpr=8192):
    return (diff_counts / cpr) * 2.0 * np.pi  # KEIN modulo!
log_timestamp = datetime.now().strftime("%Y-%m-%d_%H-%M-%S")
log_filename  = f"nmpc_log_{log_timestamp}.txt"
class Tee:
    def __init__(self, *streams):
        self.streams = streams
    def write(self, data):
        for s in self.streams:
            try:
                s.write(data)
                s.flush()
            except (ValueError, OSError):
                pass
    def flush(self):
            try:
                s.flush()
                pass
log_file = open(log_filename, 'w', encoding='utf-8')
sys.stdout = Tee(sys.__stdout__, log_file)
print(f"=== Log-Datei: {log_filename} ===")
# Model parameter
m1 = 0.09
m2 = 0.08
mh = 0.10
L_1 = 0.1492
L_2 = 0.1778
g  = 9.81
km = 0.0741
# NMPC PARAMETER und contrains
N        = 50
dt       = 0.02
T_sim    = 5
n_steps  = int(T_sim / dt)
U = 5
MODE = "swingup"   # oder "swingup"
COST_TYPE = "NONLINEAR_LS"  # "EXTERNAL" oder "NONLINEAR_LS"
if MODE == "stabilize":
    x0    = np.array([0.0, np.pi, 0.0, 0.0])
    x_ref = np.array([0.0, np.pi, 0.0, 0.0])
    Q = np.diag([100.0, 150.0, 20.0, 20.0])
    R = np.diag([1])
    B = np.diag([1])
else:  # swingup
    x0    = np.array([0.0, 0.0, 0.0, 0.0])
    Q = np.diag([1.0, 100.0, 2.0, 1.0])
    R = np.diag([1.0])
    B = np.diag([1e7])
u_ref = 0.0
U = 3.5
Q_new = np.diag([Q[0,0], Q[0,0], Q[1,1], Q[1,1], Q[2,2], Q[3,3]])
# ------------------------------------logging---------------------------
t_history = []
x_history = np.zeros((4, n_steps + 1))
u_history = np.zeros((1, n_steps))
status_history = np.zeros(n_steps)
qp_status_history = np.zeros(n_steps)
u_opt_history     = np.zeros((N, n_steps))
fallback_mask = np.zeros(n_steps, dtype=bool)  # True = Fallback wurde genutzt
solver_time = []
twincat_time = []
error_history = np.zeros((4, n_steps))
x_ekf_history     = np.zeros((4, n_steps + 1))
omega_raw_history = np.zeros((2, n_steps + 1))
# Terminal Cost (LQR)
A_down = np.array([
    [0.0,   0.0,   1.0, 0.0],
    [0.0,   0.0,   0.0, 1.0],
    [-77.7, 42.9,  0.0, 0.0],
    [57.5,  139.3, 0.0, 0.0]
B_down = np.array([[0.0], [0.0], [27.2], [18.4]])
C_mat  = np.eye(4)
D_mat  = np.zeros((4, 1))
Ad, Bd, _, _, _ = cont2discrete((A_down, B_down, C_mat, D_mat), dt, method="zoh")
_, P, _ = control.dlqr(Ad, Bd, Q, R)
# Acados Modell (CasADi symbolisch, nur für den Solver)
def build_acados_model():
    model.name = "adip"
    x = ca.MX.sym("x", 4)
    u = ca.MX.sym("u", 1)
    theta, alpha, theta_dot, alpha_dot = x[0], x[1], x[2], x[3]
    Force = u[0]
    denom = L_1**2 * (4*ca.cos(alpha)**2 * m2 - m1 - 4*m2 - 4*mh)
    theta_ddot = (
        -(1 / denom) * 2 * (
              2*L_1**2 * ca.cos(alpha)*ca.sin(alpha) * theta_dot**2 * m2
            - 2*L_1**2 * ca.cos(alpha)*ca.sin(alpha) * theta_dot * alpha_dot * m2
            + L_2*m2*L_1 * theta_dot**2 * ca.sin(alpha)
            + m2*L_2 * alpha_dot * L_1 * theta_dot * ca.sin(alpha)
            + m2*L_2 * alpha_dot**2 * L_1 * ca.sin(alpha)
            + 2*L_1 * ca.cos(alpha)**2 * ca.sin(theta) * g * m2
            + 2*L_1 * ca.cos(alpha)*ca.cos(theta)*ca.sin(alpha) * g * m2
            - m1*g*L_1 * ca.sin(theta)
            - 2*m2*g*L_1 * ca.sin(theta)
            - 2*mh*g*L_1 * ca.sin(theta)
            + 2*Force
    alpha_ddot = (
        (1 / (L_2 * denom)) * 2 * (
              4*L_1**2*L_2 * ca.cos(alpha)*ca.sin(alpha) * theta_dot**2 * m2
            + 2*L_1**2*L_2 * ca.cos(alpha)*ca.sin(alpha) * alpha_dot**2 * m2
            + L_1**3 * ca.sin(alpha) * theta_dot**2 * m1
            + 4*L_1**3 * ca.sin(alpha) * theta_dot**2 * m2
            + 4*L_1**3 * ca.sin(alpha) * theta_dot**2 * mh
            - L_1**3 * ca.sin(alpha) * theta_dot * alpha_dot * m1
            - 4*L_1**3 * ca.sin(alpha) * theta_dot * alpha_dot * m2
            - 4*L_1**3 * ca.sin(alpha) * theta_dot * alpha_dot * mh
            + L_1*L_2**2 * ca.sin(alpha) * theta_dot**2 * m2
            + L_2**2*m2*L_1 * alpha_dot * theta_dot * ca.sin(alpha)
            + m2*L_2**2 * alpha_dot**2 * L_1 * ca.sin(alpha)
            + 2*L_1*L_2 * ca.cos(alpha)**2 * ca.sin(theta) * g * m2
            + 2*L_1*L_2 * ca.cos(alpha)*ca.cos(theta)*ca.sin(alpha) * g * m2
            - L_1**2 * ca.cos(alpha)*ca.sin(theta) * g * m1
            + L_1**2 * ca.cos(theta)*ca.sin(alpha) * g * m1
            + 4*L_1**2 * ca.cos(theta)*ca.sin(alpha) * g * m2
            + 4*L_1**2 * ca.cos(theta)*ca.sin(alpha) * g * mh
            - ca.sin(theta)*g*L_1*m1*L_2
            - 2*ca.sin(theta)*g*L_1*m2*L_2
            - 2*ca.sin(theta)*g*L_1*mh*L_2
            + 4*Force*L_1*ca.cos(alpha)
            + 2*Force*L_2
    f_expl = ca.vertcat(theta_dot, alpha_dot, theta_ddot, alpha_ddot)
    xdot   = ca.MX.sym("xdot", 4)
    u_prev = ca.MX.sym("u_prev", 1)
    model.x           = x
    model.u           = u
    model.f_expl_expr = f_expl
    model.f_impl_expr = xdot - f_expl
    model.xdot        = xdot
    model.p           = u_prev
    return model
# Acados OCP Setup
if COST_TYPE == "EXTERNAL":
    def create_ocp_solver(x_ref, u_ref):
        ocp = AcadosOcp()      # create ocp object to formulate the OCP
        model = build_acados_model()          # set model
        ocp.model = model                     # set model
        nx = 4     # 4 states
        nu = 1     # 1 input
        x = ocp.model.x
        u = ocp.model.u
        u_prev = ocp.model.p
        ocp.solver_options.N_horizon = N
        ocp.parameter_values = np.array([0.0])
        ocp.cost.cost_type   = "EXTERNAL"
        ocp.cost.cost_type_e = "EXTERNAL"
        error_theta_cos = ca.cos(x[0]) - ca.cos(x_ref[0])
        error_theta_sin = ca.sin(x[0]) - ca.sin(x_ref[0])
        error_alpha_cos = ca.cos(x[1]) - ca.cos(x_ref[1])
        error_alpha_sin = ca.sin(x[1]) - ca.sin(x_ref[1])
        error_omega_1 = x[2] - x_ref[2]
        error_omega_2 = x[3] - x_ref[3]
        error_x = ca.vertcat(
        error_theta_cos,
        error_theta_sin,
        error_alpha_cos,
        error_alpha_sin,
        error_omega_1,
        error_omega_2)
        P_new = np.zeros((6, 6))
        P_new[0, 0] = P[0, 0]   # cos_theta  ← P[0,0], nicht P[2,2]
        P_new[1, 1] = P[0, 0]   # sin_theta
        P_new[2, 2] = P[1, 1]   # cos_alpha  ← P[1,1], nicht P[3,3]
        P_new[3, 3] = P[1, 1]   # sin_alpha
        P_new[4, 4] = P[2, 2]   # omega1
        P_new[5, 5] = P[3, 3]   # omega2
        error_u = u - u_ref
        change_of_u = u - u_prev
        model.cost_expr_ext_cost   = error_x.T @ Q_new @ error_x + error_u.T @ R @ error_u + change_of_u.T @ B @ change_of_u
        model.cost_expr_ext_cost_e = error_x.T @ P_new @ error_x
        ocp.constraints.x0    = x0    # Anfangsbedingung
        ocp.constraints.lbu   = np.array([-U* km])
        ocp.constraints.ubu   = np.array([U* km])
        ocp.solver_options.tf                  = N * dt          # istdas richitg für mich ?
        ocp.solver_options.integrator_type     = "IRK"           # ERK, IRK, GNSF, DISCRETE           # Explicit Runge-Kutta     # Implicit Runge-Kutta   -> IRK benutzen
        ocp.solver_options.num_stages          = 4               # 1, 2, 3, 4 (Runge-Kutta Stufen)
        ocp.solver_options.num_steps           = 1               # 1 default, 2, 3, ... (mehr = genauer, langsamer)  Number of steps in the integrator.
        ocp.solver_options.qp_solver           = "PARTIAL_CONDENSING_HPIPM"    # PARTIAL_CONDENSING_HPIPM, FULL_CONDENSING_HPIPM, FULL_CONDENSING_QPOASES
        ocp.solver_options.hpipm_mode          = "BALANCE"       # SPEED_ABS, SPEED, BALANCE, ROBUST
        ocp.solver_options.qp_solver_iter_max  = 400             # 50, 100, 200, 400, ...
        ocp.solver_options.nlp_solver_type     = "SQP_RTI"       # SQP, SQP_RTI
        ocp.solver_options.nlp_solver_max_iter = 1               # 1 (RTI), 50, 100, 200 (SQP)
        ocp.solver_options.hessian_approx      = "EXACT"  # GAUSS_NEWTON, EXACT
        ocp.solver_options.regularize_method   = "CONVEXIFY"   # NO_REGULARIZE, MIRROR, PROJECT, PROJECT_REDUC_HESS, CONVEXIFY, GERSHGORIN_LEVENBERG_MARQUARDT # nochmka nachguckebn
        ocp.solver_options.levenberg_marquardt = 0.0  # adds an constant term to the hessain
        ocp.solver_options.reg_epsilon         = 1e-2            # 1e-3, 1e-4, 1e-6, ...
        ocp.solver_options.qp_tol              = 1e-2            # 1e-3, 1e-4, 1e-6, 1e-8
        ocp.solver_options.tol                 = 1e-2            # 1e-3, 1e-4, 1e-6, 1e-8
        ocp.solver_options.print_level         = 0               # 0 (still), 1 (iter), 2 (verbose)
        ocp.solver_options.qp_solver_warm_start = 2
        solver = AcadosOcpSolver(ocp, json_file="adip_ocp.json")
        return solver
if COST_TYPE == "NONLINEAR_LS":
        nx = 4     # 4 states
        nu = 1     # 1 input
        x = ocp.model.x
        u = ocp.model.u
        ocp.cost.cost_type   = "NONLINEAR_LS"
        ocp.cost.cost_type_e = "NONLINEAR_LS"
        error_theta_cos,
        error_theta_sin,
        error_alpha_cos,
        error_alpha_sin,
        error_omega_1,
        error_omega_2)
        error_u = u - u_ref
        y_expr = ca.vertcat(
            error_x,          # 6 Einträge
            error_u,        # 1 Eintrag
            change_of_u        # 1 Eintrag
        y_expr_e = error_x    # 6 Einträge am Endknoten
        # Gewichtungsmatrix W (8x8) — Blockdiagonal aus Q_new, R, B
        W = np.zeros((8, 8))
        W[0:6, 0:6] = Q_new
        W[6:7, 6:7] = R
        W[7:8, 7:8] = B
        # Terminal-Gewichtung (6x6)
        W_e = P_new
        # In das Modell hineinreichen
        model.cost_y_expr   = y_expr
        model.cost_y_expr_e = y_expr_e
        ocp.cost.W   = W
        ocp.cost.W_e = W_e
        ocp.cost.yref   = np.zeros(8)    # Referenz = 0, weil error_x schon zentriert ist
        ocp.cost.yref_e = np.zeros(6)
        ocp.solver_options.hessian_approx      = "GAUSS_NEWTON"  # GAUSS_NEWTON, EXACT
        return solver
# Hilfsfunktionen: Lösung auslesen / Warm-Start setzen
def get_solution(solver):
    """Komplette Trajektorie aus dem Solver auslesen – analog zu sol.value(X/U)."""
    x_opt = np.array([solver.get(i, "x") for i in range(N + 1)]).T  # (4, N+1)
    u_opt = np.array([solver.get(i, "u") for i in range(N)]).T      # (1, N)
    return u_opt, x_opt
def set_warm_start(solver, x_init, u_init):
    """Warm-Start setzen – analog zu opti.set_initial(X, x_init)."""
    for i in range(N):
        solver.set(i, "x", x_init[:, i])
        solver.set(i, "u", u_init[:, i])
    solver.set(N, "x", x_init[:, N])
# ----------------Initialisierung ----------------
plc = pyads.Connection(AMS_NET_ID, pyads.PORT_TC3PLC1)
plc.open()
#encoder resetten
print("resetting values ...")
plc.write_by_name("GVL.Reset_ENC_1", True)
plc.write_by_name("GVL.Reset_ENC_2", True)
time.sleep(0.05)
plc.write_by_name("GVL.Reset_ENC_1", False)
plc.write_by_name("GVL.Reset_ENC_2", False)
time.sleep(0.05)
#enc = plc.read_by_name("GVL.Enc")
#prev_EncCounter_Ch1, prev_EncCounter_Ch2 = enc[0], enc[1]
#plc.write_by_name("GVL.Motor_value", 0) # Motor auf 0 setzen
# MPC Closed-Loop Simulation
print("Starte MPC-Simulation ...")
solver = create_ocp_solver(x_ref, u_ref)
counter = 0
t0_prev = 0
dt_actual = 0.02
# anfangsstate und u für den solver
planned_u = np.zeros((1, N))
planned_x = np.zeros((4, N + 1))
for i in range(N + 1):
    planned_x[:, i] = x0
#planned_u = np.load("u_init_from_sim.npy")
#planned_x = np.load("x_init_from_sim.npy")
# ─── Warm-Start (DFKI-Style) ───
#print("Warm-Start: 10 Iterationen am Startpunkt ...")
#for i in range(10):
#    solver.set(0, "lbx", x0)
#    solver.set(0, "ubx", x0)
#    solver.solve()
#    status = solver.status
#    print(f"  Iter {i+1}/10, status={status}")
#print("Warm-Start abgeschlossen.")
# iteration = 8000
# print("Warm-Start:  Pre-Iterationen ...")
# x0_warm = x0.copy()
# for i in range(iteration):
#     solver.set(0, "lbx", x0_warm)
#     solver.set(0, "ubx", x0_warm)
#     solver.solve()
#     x0_warm = solver.get(1, "x")
#     if i % 100 == 0:
#         print(f"  Iter {i}/iteration, status={status}", end="\r")
# print("\nWarm-Start abgeschlossen.")
arm    = x0[0]
pendle = x0[1]
omega1 = x0[2]
omega2 = x0[3]
ekf = EKF(dt=dt, x0=x0)
u_prev = 0.0   # letzter angelegter Input für EKF-Predict
try:
    while counter < n_steps:
        # getting loop time
        t0 = time.perf_counter()
        if counter > 1:
            dt_actual = t0 - t0_prev
        t_history.append(dt_actual)
        t0_prev = t0
        #getting encoder values and time
        time_twincat_1 = time.perf_counter()
        EncCounter_Ch1, EncCounter_Ch2 = enc[0], enc[1]      # raw value
        time_twincat_2 = time.perf_counter()
        twincat_time.append(time_twincat_2 - time_twincat_1)   # ← das hier fehlt
        # # Differenz mit Überlauf-Behandlung berechnen
        # diff_EncCounter_Ch1 = handle_encoder_overflow(EncCounter_Ch1, prev_EncCounter_Ch1, UINT16_MAX)
        # diff_EncCounter_Ch2 = handle_encoder_overflow(EncCounter_Ch2, prev_EncCounter_Ch2, UINT16_MAX)
        # # Werte berechnen
        # arm    = EncCounter_Ch1 * 2*np.pi/ENCODER_CPR_ARM
        # pendle = EncCounter_Ch2 * 2*np.pi/ENCODER_CPR_PENDLE
        # #arm = np.arctan2(np.sin(arm), np.cos(arm))
        # #pendle = np.arctan2(np.sin(pendle), np.cos(pendle))
        # if counter > 1:
        #     arm    += counts_to_rad_delta(diff_EncCounter_Ch1, ENCODER_CPR_ARM)
        #     pendle += counts_to_rad_delta(diff_EncCounter_Ch2, ENCODER_CPR_PENDLE)
        #     omega1 = counts_to_rad_delta(diff_EncCounter_Ch1, ENCODER_CPR_ARM) / dt_actual
        #     omega2 = counts_to_rad_delta(diff_EncCounter_Ch2, ENCODER_CPR_PENDLE) / dt_actual
        if counter > 0:
        x_hat = ekf.update(u_prev, arm, pendle)
        x_ekf_history[:, counter - 1]     = x_hat
        omega_raw_history[:, counter - 1] = [omega1, omega2]
        # Aktueller Zustand
        x_current = np.array([arm, pendle, x_hat[2], x_hat[3]])
        # Aktueller Zustand
        #x_current = np.array([arm, pendle, omega1, omega2])
        x_history[:, counter - 1] = x_current
        error_x = x_current - x_ref
        error_history[:, counter - 1] = error_x
        # Anfangsbedingung setzen
        solver.set(0, "lbx", x_current)
        solver.set(0, "ubx", x_current)
        for i in range(N):
            solver.set(i, "p", np.array([planned_u[0, i]]))
        solver_1 = time.perf_counter()
        solver.solve()
        solver_2 = time.perf_counter()
        solver_time_current = solver_2 - solver_1
        solver_time.append(solver_time_current)
        qp_status = solver.get_stats('qp_stat')
        if status == 0:
                # Erfolgreich: Neue Lösung auslesen und anwenden
                u_opt, x_opt = get_solution(solver)
                u_apply = np.clip(float(u_opt[0, 0]) / km, -U, U)
                input = -1 * u_apply * 555.556
                motor_value = int(input)
                plc.write_by_name("GVL.Motor_value", motor_value)
                # Trajektorie für den NÄCHSTEN Schritt vorbereiten
                planned_u = np.hstack([u_opt[:, 1:], u_opt[:, -1:]])
                planned_x = np.hstack([x_opt[:, 1:], x_opt[:, -1:]])
                # Warm-Start und Logging nur bei Erfolg
                u_opt_history[:, counter - 1] = u_opt[0, :] / km
        else:
            u_apply = np.clip(float(planned_u[0, 0]) / km, -U, U)
            print(f"Schritt {counter}: Solver Status = {status} -> Nutze Fallback!  u_apply = {u_apply}   " )
            # Gespeicherte Trajektorie weiter nach links verschieben
            planned_u = np.hstack([planned_u[:, 1:], planned_u[:, -1:]])
            planned_x = np.hstack([planned_x[:, 1:], planned_x[:, -1:]])
            fallback_mask[counter - 1] = True
            u_opt_history[:, counter - 1] = planned_u[0, :]
        # Status loggen
        status_history[counter - 1]    = status
        qp_status_history[counter - 1] = qp_status[-1]
        u_history[:, counter - 1]      = u_apply
        # Warm-Start für nächsten Schritt setzen
        set_warm_start(solver, planned_x, planned_u)
        # ---------- loggen ----------
        print(
            f"Schritt {counter} | Status={status} | "
            f"input = {u_opt[0, 0]/ km}, u={u_apply}| motorvalue= {motor_value:6d} | "
            f"θ1={np.rad2deg(arm):+7.2f} deg, "
            f"θ2={np.rad2deg(pendle):+7.2f} deg, "
            f"ω1={omega1:+7.2f} rad/s, "
            f"ω2={omega2:+7.2f} rad/s | "
            f"e_θ={np.rad2deg(error_x[0]):+7.2f}°, "
            f"e_α={np.rad2deg(error_x[1]):+7.2f}°, "
        # Update für nächste Iteration
        prev_EncCounter_Ch1 = EncCounter_Ch1
        prev_EncCounter_Ch2 = EncCounter_Ch2
        counter = counter + 1
        u_prev = u_apply * km
        while time.perf_counter() - t0 < dt:
            pass
except KeyboardInterrupt:
    print("\nProgramm beendet.")
finally:
    plc.write_by_name("GVL.Motor_value", 0)  # Motor ausschalten
    plc.close()
    print("PLC-Verbindung geschlossen.")
    sys.stdout = sys.__stdout__
    log_file.close()
# Plots (3x3 Grid)
n_actual = len(t_history)
t_vec    = np.arange(n_actual + 1) * dt
t_u_vec  = np.arange(n_actual) * dt
T_arr    = np.array(t_history)
u_current = u_history.flatten()[:n_actual]
u_force   = u_current * km
fig, axes = plt.subplots(4, 3, figsize=(16, 16))
fig.suptitle('NMPC – ADIP Reales System', fontsize=16)
# ── NEU: Matrizen als Text-Box einfügen ──────────────────────────────────────
q_diag = np.diag(Q)
r_diag = np.diag(R)
b_diag = np.diag(B)
matrix_text = (
    f"Q = [{q_diag[0]:.2f},  {q_diag[1]:.0f},  {q_diag[2]:.2f},  {q_diag[3]:.1f}]\n"
    f"R = [{r_diag[0]:.0f}]\n"
    f"B = [{b_diag[0]:.0f}]"
fig.text(
    0.5, 0.950,
    matrix_text,
    ha='center', va='top',
    fontsize=9, family='monospace',
    bbox=dict(boxstyle='round,pad=0.3', facecolor='lightyellow',
              edgecolor='gray', alpha=0.8),
    multialignment='center'    # ← sorgt dafür, dass jede Zeile für sich zentriert ist
# ================= LINKE SPALTE =================
# --- [0,0]: Arm-Winkel theta ---
ax = axes[0, 0]
ax.plot(t_vec[:n_actual+1], np.rad2deg(x_history[0, :n_actual+1]), label=r'$\theta_1$ Arm', color='steelblue')
ax.axhline(np.rad2deg(x_ref[0]), linestyle='--', linewidth=1, color='steelblue', label=r'$\theta_{1,ref}$')
ax.set_xlabel('Zeit [s]')
ax.set_ylabel('Winkel [°]')
ax.set_title(r'Arm-Winkel $\theta$')
ax.grid(True)
ax.legend()
# --- [1,0]: Pendel-Winkel alpha ---
ax = axes[1, 0]
ax.plot(t_vec[:n_actual+1], np.rad2deg(x_history[1, :n_actual+1]), label=r'$\theta_2$ Pendel', color='orange')
ax.axhline(np.rad2deg(x_ref[1]), linestyle='--', linewidth=1, color='orange', label=r'$\theta_{2,ref}$')
ax.set_title(r'Pendel-Winkel $\alpha$')
ax.grid(True)
ax.legend()
# --- [2,0]: Winkelgeschwindigkeiten ---
ax = axes[2, 0]
ax.plot(t_vec[:n_actual+1], x_history[2, :n_actual+1], label=r'$\dot{\theta}_1$ Arm')
ax.plot(t_vec[:n_actual+1], x_history[3, :n_actual+1], label=r'$\dot{\theta}_2$ Pendel')
ax.axhline(0.0, linestyle='--', linewidth=1, label='ref = 0')
ax.set_ylabel('Winkelgeschwindigkeit [rad/s]')
ax.set_title('Winkelgeschwindigkeiten')
ax.grid(True)
ax.legend()
# ================= MITTLERE SPALTE =================
# --- [0,1]: Haupt-Solver Status ---
ax = axes[0, 1]
ax.step(t_u_vec[:n_actual], status_history[:n_actual], where='post', color='red', label='NLP Status')
ax.set_yticks(range(9))
ax.set_yticklabels([
    '0: Success', '1: NaN', '2: MaxIter', '3: MinStep',
    '4: QP Fail', '5: Ready', '6: Unbounded', '7: Timeout', '8: QP Bounds'
], fontsize=8)
ax.set_ylim(-0.5, 8.5)
ax.set_ylabel('Status Code')
ax.set_title('Haupt-Solver Status (acados)')
ax.grid(True, axis='y', linestyle='--', alpha=0.7)
ax.legend(loc='upper right')
# --- [1,1]: QP Solver Status ---
ax = axes[1, 1]
ax.step(t_u_vec[:n_actual], qp_status_history[:n_actual], where='post', color='purple', label='QP Status')
ax.set_yticks([-1, 0, 1, 2, 3, 9])
    '-1: Unknown', '0: Success', '1: NaN',
    '2: MaxIter', '3: MinStep', '9: Infeasible'
], fontsize=8)
ax.set_ylim(-1.5, 9.5)
ax.set_ylabel('QP Status Code')
ax.set_title('Unter-Solver Status (HPIPM)')
# --- [2,1]: Timing ---
ax = axes[2, 1]
solver_arr  = np.array(solver_time[:n_actual])  * 1000.0
twincat_arr = np.array(twincat_time[:n_actual]) * 1000.0
ax.plot(t_u_vec[:n_actual], T_arr * 1000.0, label='Loop time',     color='steelblue',  linewidth=1.2)
ax.plot(t_u_vec[:n_actual], solver_arr,     label='Solver time',   color='green',      linewidth=1.2)
ax.plot(t_u_vec[:n_actual], twincat_arr,    label='TwinCAT (ADS)', color='darkorange', linewidth=1.2)
ax.axhline(dt * 1000.0, linestyle='--', color='red', linewidth=1, label=f'dt = {dt*1000:.0f} ms (Deadline)')
ax.set_ylabel('Zeit [ms]')
ax.set_title('Timing-Aufschlüsselung pro Schritt')
ax.grid(True)
ax.legend(fontsize=8)
# ================= RECHTE SPALTE =================
# --- [0,2]: Stellgröße Force ---
ax = axes[0, 2]
ax.step(t_u_vec[:n_actual], u_force, where='post', label='Force [N]', color='steelblue', linewidth=1.5)
ax.axhline( U * km, linestyle='--', color='red',  linewidth=1, label='U_max')
ax.axhline(-U * km, linestyle='--', color='blue', linewidth=1, label='U_min')
ax.set_ylabel('Force [N]')
ax.set_title('Stellgröße u (Force)')
ax.grid(True, alpha=0.4)
# --- [1,2]: Stellgröße Strom ---
ax = axes[1, 2]
ax.step(t_u_vec[:n_actual], u_current, where='post', label='Strom [A]', color='orange', linewidth=1.5)
ax.axhline( U, linestyle='--', color='red',  linewidth=1, label='I_max')
ax.axhline(-U, linestyle='--', color='blue', linewidth=1, label='I_min')
ax.set_ylabel('Strom [A]')
ax.set_title('Stellgröße u (Strom)')
# --- [2,2]: Fehler-Plot (Winkel) mit Fallback-Markierung ---
ax = axes[2, 2]
ax.plot(t_u_vec[:n_actual], np.rad2deg(error_history[0, :n_actual]),
        label=r'$e_{\theta}$ (Arm)', color='steelblue')
ax.plot(t_u_vec[:n_actual], np.rad2deg(error_history[1, :n_actual]),
        label=r'$e_{\alpha}$ (Pendel)', color='orange')
ax.axhline(0, color='black', linestyle='--', linewidth=0.8)
# Fallback-Bereiche markieren
i = 0
while i < n_actual:
    if fallback_mask[i]:
        start = i
        while i < n_actual and fallback_mask[i]:
            i += 1
        ax.axvspan(start * dt, i * dt, color='red', alpha=0.15, zorder=0)
    else:
        i += 1
from matplotlib.patches import Patch
fallback_patch = Patch(facecolor='red', alpha=0.15, label='Fallback aktiv')
ax.legend(handles=ax.get_legend_handles_labels()[0] + [fallback_patch], fontsize=8)
ax.set_ylabel('Fehler [°]')
ax.set_title('Regelfehler (Winkel)')
ax.grid(True, alpha=0.3)
# ═════════════ ZEILE 4: EKF vs. Encoder Vergleich ═════════════
# --- [3,0]: Winkel (beide) — Encoder vs. EKF ---
ax = axes[3, 0]
        label=r'$\theta$ Encoder', color='steelblue', linewidth=1.5)
ax.plot(t_vec[:n_actual+1], np.rad2deg(x_ekf_history[0, :n_actual+1]),
        label=r'$\theta$ EKF', color='steelblue',
        linestyle='--', linewidth=1.2, alpha=0.7)
        label=r'$\alpha$ Encoder', color='orange', linewidth=1.5)
ax.plot(t_vec[:n_actual+1], np.rad2deg(x_ekf_history[1, :n_actual+1]),
        label=r'$\alpha$ EKF', color='orange',
ax.axhline(0, linestyle=':', linewidth=1, color='black', alpha=0.5)
ax.set_title('Winkel: Encoder vs. EKF')
ax.grid(True)
ax.legend(fontsize=7, ncol=2)
# --- [3,1]: ω1 (Arm) — Encoder vs. EKF ---
ax = axes[3, 1]
ax.plot(t_vec[:n_actual+1], omega_raw_history[0, :n_actual+1],
        label='Encoder', color='steelblue', linewidth=2.0)
ax.plot(t_vec[:n_actual+1], x_ekf_history[2, :n_actual+1],
        label='EKF', color='darkblue', linewidth=1.5, linestyle='--')
ax.axhline(0.0, linestyle=':', linewidth=1, color='red', alpha=0.5)
ax.set_ylabel(r'$\dot{\theta}_1$ [rad/s]')
ax.set_title(r'Arm-Geschwindigkeit $\dot{\theta}_1$')
ax.grid(True)
# --- [3,2]: ω2 (Pendel) — Encoder vs. EKF ---
ax = axes[3, 2]
ax.plot(t_vec[:n_actual+1], omega_raw_history[1, :n_actual+1],
        label='Encoder', color='orange', linewidth=2.0)
ax.plot(t_vec[:n_actual+1], x_ekf_history[3, :n_actual+1],
        label='EKF', color='darkorange', linewidth=1.5, linestyle='--')
ax.set_ylabel(r'$\dot{\theta}_2$ [rad/s]')
ax.set_title(r'Pendel-Geschwindigkeit $\dot{\theta}_2$')
ax.grid(True)
plt.tight_layout(rect=[0, 0, 1, 0.945])   # Platz für den Text oben freilassen
plt.savefig(rf"C:\Users\mz\Desktop\exp2-adip\Bilder\NMPC_control_pictures\nmpc_adip_{timestamp}.png", dpi=150, bbox_inches='tight')
plt.show()
SQP_RTI: QP solver returned error status 3 (ACADOS_MINSTEP) QP iteration 1.
Schritt 243: Solver Status = 4 -> Nutze Fallback!  u_apply = 3.4999999999999996
Schritt 243 | Status=4 | input = 3.4999999999999996, u=3.4999999999999996| motorvalue=  -1944 | θ1= +51.99 deg, θ2=+271.85 deg, ω1=  -0.27 rad/s, ω2= -14.34 rad/s | e_θ= +51.99°, e_α= +91.85°,
SQP_RTI: QP solver returned error status 3 (ACADOS_MINSTEP) QP iteration 3.
Schritt 244: Solver Status = 4 -> Nutze Fallback!  u_apply = 3.4999999999999996
Schritt 244 | Status=4 | input = 3.4999999999999996, u=3.4999999999999996| motorvalue=  -1944 | θ1= +50.27 deg, θ2=+259.72 deg, ω1=  -1.50 rad/s, ω2= -10.58 rad/s | e_θ= +50.27°, e_α= +79.72°,
Schritt 245: Solver Status = 4 -> Nutze Fallback!  u_apply = 3.4999999999999996
Schritt 245 | Status=4 | input = 3.4999999999999996, u=3.4999999999999996| motorvalue=  -1944 | θ1= +47.81 deg, θ2=+250.84 deg, ω1=  -2.15 rad/s, ω2=  -7.75 rad/s | e_θ= +47.81°, e_α= +70.84°,
SQP_RTI: QP solver returned error status 3 (ACADOS_MINSTEP) QP iteration 2.
Schritt 246: Solver Status = 4 -> Nutze Fallback!  u_apply = 3.4999999999999996
Schritt 246 | Status=4 | input = 3.4999999999999996, u=3.4999999999999996| motorvalue=  -1944 | θ1= +44.21 deg, θ2=+243.28 deg, ω1=  -3.14 rad/s, ω2=  -6.60 rad/s | e_θ= +44.21°, e_α= +63.28°,
Schritt 247: Solver Status = 4 -> Nutze Fallback!  u_apply = 3.4999999999999996
Schritt 247 | Status=4 | input = 3.4999999999999996, u=3.4999999999999996| motorvalue=  -1944 | θ1= +40.08 deg, θ2=+238.10 deg, ω1=  -3.60 rad/s, ω2=  -4.52 rad/s | e_θ= +40.08°, e_α= +58.10°,
Hi Rick,
min step can be due to very ill consitioned QPs. Which QP solver are you using? Have you tried scaling your problem.
Hope this helps :rocket:
Katrin
Hi i am using PARTIAL_CONDENSING_HPIPM as a QP solver. I tried every one but it didnt solve my problem. Kind regards
