Getting "z" from AcadosSimSolver
I am using acados with Python interface to solve a closed_loop_mhe_ocp procram using my own model instead of export_pendulum_ode_model(). I took as starting point the closed_loop_mhe_ocp.py example in acados/examples/acados_python/getting_started/mhe.
I would need to get an algebraic variable “z” from acados_integrator (instantiation of class AcadosSimSolver) after having solved it but, with my great surprise I saw that, differently from AcadosOcpSolver, that’s not possible as you can see hereafter:
def get(self, field_):
get the last solution of the solver:
    :param field_: string in ['x', 'u', 'S_forw', 'Sx', 'Su', 'S_adj', 'S_hess']
Is there a main reason for that? Would it be difficult to implement in the function get also “z” in the param field_?
Many Thanks
Cheers
Walter
Hi Walter,
you are right, that was missing!
I just made a PR to add it:
thanks a lot for your prompt response! :+1::slightly_smiling_face:
BR,
Walter
