Hi Jonathan, ![]()
I am using acados to solve an ocp in power grids, and for now, I am using the well know benchmark 9bus system. This model is a DAE system with 12 dynamic states, 27 algebraic states, and 6 inputs. I am also using the Matlab interface with Casadi 3.5.5. I want to use an objective function that includes some algebraic variables, it works when I use the built-in objective function (‘linear_ls’), but it crashes when I write the same function as external objective function (‘ext_cost’). If I use only the dynamic states and inputs the external objective function works well. When I use the algebraic states in the external objective I got the following error message:
Error using casadi.Function/generate (line 1245)
.../casadi/core/sx_function.cpp:149: Code generation of 'dae_9Bus_cost_ext_cost_fun' is not
possible since variables [ex_0, ex_1, ex_2, ey_0, ey_1, ey_2, ix_0, ix_1, ix_2, iy_0, iy_1,
iy_2, id_0, id_1, id_2, iq_0, iq_1, iq_2, ed_0, ed_1, ed_2, eq_0, eq_1, eq_2, Pe_0, Pe_1,
Pe_2] are free.
Error in casadi.Function/subsref (line 1753)
[varargout{1:nargout}] = builtin('subsref',self,s);
Error in generate_c_code_ext_cost (line 90)
ext_cost_fun.generate([model_name,'_cost_ext_cost_fun'], casadi_opts);
Error in ocp_generate_casadi_ext_fun (line 150)
generate_c_code_ext_cost(model_struct, opts_struct);
Error in acados_ocp (line 194)
ocp_generate_casadi_ext_fun(obj.model_struct, obj.opts_struct);
Error in ocp_9bus (line 153)
You can reproduce this error with the following simulation files. The different options for the objective function can be selected in lines 35 and 36 of the second file.
function model = dae_9bus()
%% CasADi
import casadi.*
model_name_prefix = 'dae_9bus';
%% Parameters
ws=2*pi*60;
H = [ 23.64 6.40 3.01 ]';
D = [ 0 0 0 ]';
Xd = [ 0.1460 0.8958 1.3125 ]';
Xq = [ 0.0969 0.8465 1.2578 ]';
Xds = [ 0.0608 0.1198 0.1813 ]';
% Xqs = [ 0.0969 0.1969 0.2500 ]'; %for updating Y OR
Xqs = Xds; % so that Y is a constant matrix, see paper page 3
Tds0 = [ 8.9600 6.0000 5.8900 ]';
Tqs0 = [ 0.6000 0.5350 0.6000 ]';
Ra = [ 0 0 0 ]';
Y=[ 0.8455 2.9883 0.2871 -1.5129 0.2096 -1.2259
-2.9883 0.8455 1.5129 0.2871 1.2256 0.2096
0.2871 -1.5129 0.4200 2.7239 0.2133 -1.0879
1.5129 0.2871 -2.7239 0.4200 1.0879 0.2133
0.2096 -1.2256 0.2133 -1.0879 0.2770 2.3681
1.2256 0.2096 1.0879 0.2133 -2.3681 0.2770
%% initial values
x0 = [ 9.8598e-02
1.0343e+00
9.1743e-01
0
0
0
8.9957e-01
6.7692e-01
5.9303e-01
2.5647e-02
5.6773e-01
5.4621e-01];
z0 = [ 8.9773e-01
8.3395e-01
7.9420e-01
6.3030e-02
2.9167e-01
1.3887e-01
7.4177e-01
1.3254e+00
5.2034e-01
-2.8150e-01
1.2081e-01
2.4066e-01
3.5315e-01
1.0775e+00
2.6689e-01
7.1045e-01
7.8125e-01
5.0739e-01
-1.7548e-02
4.7414e-01
4.5422e-01
8.7810e-01
5.4783e-01
5.4465e-01
6.1765e-01
9.3888e-01
3.9758e-01];
u0 = [ 6.1765e-01
9.3888e-01
3.9758e-01
9.2966e-01
1.5131e+00
8.9493e-01];
%% Set up States & Controls
% Differential States
delta = SX.sym('delta',3,1);
w = SX.sym('w',3,1);
eqs = SX.sym('eqs',3,1);
eds = SX.sym('eds',3,1);
x = vertcat(delta, w, eds, eqs);
nx = length(x);
% Algebraic states
ex = SX.sym('ex',3,1);
ey = SX.sym('ey',3,1);
ix = SX.sym('ix',3,1);
iy = SX.sym('iy',3,1);
id = SX.sym('id',3,1);
iq = SX.sym('iq',3,1);
eq = SX.sym('eq',3,1);
ed = SX.sym('ed',3,1);
Pe = SX.sym('Pe',3,1);
z = vertcat(ex, ey, ix, iy, id, iq, ed, eq, Pe);
nz = length(z);
% Controls % applied torque
Pm = SX.sym('Pm',3,1);
Efq = SX.sym('Efq',3,1);
u = vertcat(Pm, Efq);
nu = length(u);
%% xdot
delta_dot = SX.sym('delta_dot',3); % Differential States
w_dot = SX.sym('w_dot',3);
eqs_dot = SX.sym('eqs_dot',3);
eds_dot = SX.sym('eds_dot',3);
xdot = [delta_dot; w_dot; eqs_dot; eds_dot];
%% cost
W_x = 1*diag(ones(1,nx));
W_u = 1e-1*diag(ones(1,nu));
W_z = 1*diag(ones(1,nz));
W_e = 1*W_x;
expr_ext_cost_e = (x-x0)'* W_e *(x-x0);
expr_ext_cost_xu = (x-x0)'* W_x *(x-x0) + (u-u0)'* W_u *(u-u0);
expr_ext_cost_xuz = (x-x0)'* W_x *(x-x0) + (z-z0)'*W_z*(z-z0) + (u-u0)'* W_u *(u-u0);
%% Dynamics: implicit DAE formulation (index-1)
f_impl = vertcat(delta_dot - ws.*w, ...
w_dot - (Pm-Pe-D.*w)./(2*H), ...
eqs_dot - (Efq-(Xd-Xds).*id-eqs)./Tds0, ...
eds_dot - ((Xq-Xqs).*iq-eds)./Tqs0, ...
ex - (sin(delta).*eds + cos(delta).*eqs), ...
ey - (-cos(delta).*eds + sin(delta).*eqs), ...
[ix; iy] - Y*[ex;ey], ...
id - (sin(delta).*ix - cos(delta).*iy), ...
iq - (cos(delta).*ix + sin(delta).*iy), ...
ed - (eds - Ra.*id + Xqs.*iq), ...
eq - (eqs - Xds.*id - Ra.*iq), ...
Pe - (ed.*id + eq.*iq));
%% model struct
model.expr_f_impl = f_impl;
model.sym_x = x;
model.sym_xdot = xdot;
model.sym_u = u;
model.sym_z = z;
model.name = model_name_prefix;
model.expr_ext_cost_xu = expr_ext_cost_xu;
model.expr_ext_cost_xuz = expr_ext_cost_xuz;
model.expr_ext_cost_e = expr_ext_cost_e;
model.nx = nx;
model.nz = nz;
model.nu = nu;
model.x0 = x0;
model.z0 = z0;
model.u0 = u0;
clear all
close all
clc
model_name = 'dae_9Bus';
%% options
compile_interface = 'auto'; % true, false
codgen_model = 'true'; % true, false
% ocp
N = 20;
nlp_solver = 'sqp'; % sqp, sqp_rti
nlp_solver_exact_hessian = 'true';
regularize_method = 'no_regularize';
nlp_solver_max_iter = 10;
nlp_solver_tol_stat = 1e-12;
nlp_solver_tol_eq = 1e-12;
nlp_solver_tol_ineq = 1e-12;
nlp_solver_tol_comp = 1e-12;
nlp_solver_ext_qp_res = 1;
nlp_solver_step_length = 0.7;
qp_solver = 'partial_condensing_hpipm'; % partial_condensing_hpipm
qp_solver_cond_N = 5;
qp_solver_warm_start = 2;
qp_solver_cond_ric_alg = 1; % 0: dont factorize hessian in the condensing; 1: factorize
qp_solver_ric_alg = 1; % HPIPM specific
ocp_sim_method = 'irk'; % irk, irk_gnsf
ocp_sim_method_num_stages = 2; % scalar or vector of size ocp_N;
ocp_sim_method_num_steps = 2; % scalar or vector of size ocp_N;
ocp_sim_method_newton_iter = 2; % scalar or vector of size ocp_N;
% selectors for example variants
cost_type = 'external'; % 'internal' or 'external'
ext_variables = 1; % 0: xu or 1: xuz
% get model
model = dae_9bus;
x0 = model.x0;
z0 = model.z0;
u0 = model.u0;
nx = model.nx;
nz = model.nz;
nu = model.nu;
ny = nx+nu+nz;
h = 0.01;
T = N*h;
%% acados ocp model
ocp_model.set('T', T);
ocp_model.set('name', model_name);
% symbolics
ocp_model.set('sym_x', model.sym_x);
ocp_model.set('sym_u', model.sym_u);
ocp_model.set('sym_xdot', model.sym_xdot);
ocp_model.set('sym_z', model.sym_z);
% cost
if cost_type == 'external'
ocp_model.set('cost_type', 'ext_cost');
ocp_model.set('cost_type_e', 'ext_cost');
if ext_variables == 0
ocp_model.set('cost_expr_ext_cost', model.expr_ext_cost_xu);
elseif ext_variables == 1
ocp_model.set('cost_expr_ext_cost', model.expr_ext_cost_xuz);
ocp_model.set('cost_expr_ext_cost_e', model.expr_ext_cost_e);
else
% state-to-output matrix in lagrange term
Vx = eye(ny, nx);
% input-to-output matrix in lagrange term
Vu = zeros(ny, nu);
Vu(nx+1:nx+nu, :) = eye(nu);
% algebraic-to-output matrix in lagrange term
Vz = zeros(ny, nz);
Vz(nx+nu+1:end, :) = eye(nz);
% state-to-output matrix in mayer term
Vx_e = eye(nx);
% weight matrix in lagrange term
Wx = 1*ones(1,nx);
Wu = 1*ones(1,nu);
Wz = 1*ones(1,nz);
W = diag([Wx,Wu,Wz]);
yr = [x0;u0;z0];
% weight matrix in mayer term
W_e = 1*diag(Wx);
yr_e = x0; % output reference in mayer term
%ocp_model struct
ocp_model.set('cost_type', 'linear_ls');
ocp_model.set('cost_type_e', 'linear_ls');
ocp_model.set('cost_Vu', Vu);
ocp_model.set('cost_Vz', Vz);
ocp_model.set('cost_Vx', Vx);
ocp_model.set('cost_Vx_e', Vx_e);
ocp_model.set('cost_W_e', W_e);
ocp_model.set('cost_W', W);
ocp_model.set('cost_y_ref', yr);
ocp_model.set('cost_y_ref_e', yr_e);
% dynamics
ocp_model.set('dyn_type', 'implicit');
ocp_model.set('dyn_expr_f', model.expr_f_impl);
% constraints
x_traj_init = repmat(x0, 1, N + 1);
u_traj_init = u0.*ones(model.nu, N);
z_traj_init = z0.*ones(model.nz, N);
xdot_traj_init = 0*ones(model.nx, N);
%% acados ocp opts
ocp_opts = acados_ocp_opts();
ocp_opts.set('compile_interface', compile_interface);
ocp_opts.set('codgen_model', codgen_model);
ocp_opts.set('nlp_solver_exact_hessian', nlp_solver_exact_hessian);
ocp_opts.set('regularize_method', regularize_method);
ocp_opts.set('nlp_solver_ext_qp_res', nlp_solver_ext_qp_res);
ocp_opts.set('nlp_solver_step_length', nlp_solver_step_length);
if (strcmp(nlp_solver, 'sqp'))
ocp_opts.set('nlp_solver_max_iter', nlp_solver_max_iter);
ocp_opts.set('nlp_solver_tol_stat', nlp_solver_tol_stat);
ocp_opts.set('nlp_solver_tol_eq', nlp_solver_tol_eq);
ocp_opts.set('nlp_solver_tol_ineq', nlp_solver_tol_ineq);
ocp_opts.set('nlp_solver_tol_comp', nlp_solver_tol_comp);
ocp_opts.set('qp_solver', qp_solver);
if (strcmp(qp_solver, 'partial_condensing_hpipm'))
ocp_opts.set('qp_solver_cond_N', qp_solver_cond_N);
ocp_opts.set('qp_solver_cond_ric_alg', qp_solver_cond_ric_alg);
ocp_opts.set('qp_solver_ric_alg', qp_solver_ric_alg);
ocp_opts.set('qp_solver_warm_start', qp_solver_warm_start);
ocp_opts.set('sim_method', ocp_sim_method);
ocp_opts.set('sim_method_num_stages', ocp_sim_method_num_stages);
ocp_opts.set('sim_method_num_steps', ocp_sim_method_num_steps);
ocp_opts.set('sim_method_newton_iter', ocp_sim_method_newton_iter);
ocp_opts.set('exact_hess_dyn', 1);
ocp_opts.set('exact_hess_cost', 1);
ocp_opts.set('exact_hess_constr', 1);
%% acados ocp
ocp.set('init_z', z_traj_init);
ocp.set('init_xdot', xdot_traj_init);
ocp.solve();
stat = ocp.get('stat');
ocp.print('stat')
status = ocp.get('status');
sqp_iter = ocp.get('sqp_iter');
sqp_time = ocp.get('time_tot');
format short e
% get solution for initialization of next NLP
x_traj = ocp.get('x');
u_traj = ocp.get('u');
z_traj = ocp.get('z');
%plot result
figure;
Nsub = 3;
subplot(Nsub, 1, 1);
plot(x_traj');
legend('x');
subplot(Nsub, 1, 2);
plot(z_traj');
legend('z');
subplot(Nsub, 1, 3);
plot(u_traj');
legend('u');
Can you help me to solve this issue?
Best regards, ![]()
Paulo
