dSPACE Compiler host/target folder
Hi!
I’m having some issues following the procedure to compile acados on dSPACE for an integration with MicroAutoBox II. On Step 1: Adapt the existing CMake toolchain file for your system I should be able to find on C:/ProgramData/dSPACE/ the following folders/files:
/Compiler/QNX650_520/host/win32/x86/
/Compiler/QNX650_520/target/qnx6/
However, I can’t find them in any of the dSPACE related folder I have on my PC.
I’m inheriting a dSPACE project and the files related to the compilation (such as dSPACE_Model_Name’_usr.mk and others) have been generated. Is there any chance that these two folders/files to be generated during this compilation process or they should be there already before the compilation? I’ve asked other colleagues and they don’t have these folders/files neither.
Am I missing something?
FYI:
Matlab 2017b
dSPACE 2018-B
Thanks for your time,
Daniel
Hi everyone, solved it.
The problem solution is described on:
faq142.pdf (dspace.com)
Daniel
