I have formulated an MPC with ACADOS. When using the generated s-function in Simulink I receive the solver status = 1. This means that there is some kind of ACADOS_Failure. I looked at this post which describes a similar error (Error status 1, what can I do to investigate this problem?), but it was not helpful to me.
I think it has something to do with my problem formulation, but I have used the same formulation in a different toolbox and it worked. Yesterday I tried many things to solve the issue, but I was not successful.
Can someone maybe give me some advice how to debug this issue.
If it is helpful, i can send my problem formulation, the main script for generating the s-function and the simulink model.
the forum post you are referring to is a bit outdated. Solver status 1 means that there have been NaNs detected.
Typically, NaNs results from a division by zero/a logarithm of a negative number/etc. Please check your problem functions, i.e. all CasADi functions defining your cost/dynamics/constraints.
thanks for your response. I checked the casadi functions and I was able to solve the problem. It had something to do with too tight constraints and a missing integrator in the process mdel.
