I am working with acados in python and have a question regarding the formulation for the CONVEX_OVER_NONLINEAR cost formulation. I was previously using NONLINEAR_LS as discussed in neural-network-as-terminal-cost which allowed me to use a neural network as the terminal cost. However, due to some other pytorch/training related issues I have to move away from NONLINEAR_LS.
Basically, I still want to exploit the GAUSS_NEWTON approximation but without acados performing the least squares operation on the output of the neural network. I saw something similar suggested in this post and I think this also applies to me.
Previously, I fed V_\theta(x) as the cost_y_expr_e but now I am feeding f instead.
f = \frac{1}{2}(V_\theta(x))^2
This is my previous code for implementing the terminal cost with NONLINEAR_LS.
def define_terminal_cost(self, ocp, model, config):
# Extract dims
nx = model.x.rows()
self.ny_e = self.ee_expr.shape[0]+ nx//2
# Create parameters for goal, obstacle
self.p = np.array(self.config["mpc"]["yref"])
ocp.model.p = SX.sym('p', self.p.shape[0]) # Full yref as parameter
ocp.parameter_values = np.zeros(self.p.shape[0])
# Export trained NN model (It can be assumed that the exported model is V)
self.l4c_model = export_torch_model(config, self.worker_id)
# Set NN as y_expr_e
y_sym = self.l4c_model(ca.transpose(vertcat(model.x, ocp.model.p)))
ocp.model.cost_y_expr_e = y_sym
# Set cost type, weights and yref
ocp.cost.cost_type_e = 'NONLINEAR_LS' # Terminal cost
ocp.cost.W_e = np.eye(y_sym.shape[0]) # Weights set to 1, meaning no scaling for the NN output
ocp.cost.yref_e = np.zeros((y_sym.shape[0], )) # Set terminal reference to zero for NN output
And this is the new workflow for CONVEX_OVER_NONLINEAR
# Extract dims
nx = model.x.rows()
# Export trained NN model (It can be assumed that the exported model is f)
x_aug = ca.transpose(ca.vertcat(model.x, ocp.model.p))
y_sym = ca.transpose(self.l4c_model(x_aug))
ocp.cost.cost_type_e = 'CONVEX_OVER_NONLINEAR' # Terminal cost
r = ca.SX.sym("r")
ocp.model.cost_r_in_psi_expr_e = r
# identity convex function
ocp.model.cost_psi_expr_e = r
I was wondering if I have implemented r and phi correctly?
Thank you for any help.
Nicodemus
