Greetings! Is it possible to change the parameters passed to the cost function at every shooting node without using “solver parameter”. In other words, could i make changes on cost function without parameters solver?
Thanks in advance.
Muhammad
Thanks in advance.
Muhammad
If you want to change the cost function without solver parameters, you have to use either LINEAR_LS or NONLINEAR_LS cost formulations.
Then you can update the weight matrix W
and the reference vector y_ref
at each shooting node individually.
Thanks @FreyJo for answer.
